Question about RCA Audio Players & Recorders
How to hook up technics sh-ge70
Hello trying to hook up a pioneer pl-200 to a technics sh-ge70 then to a jvc Rx-888v. so I have the only rca from record player going to the imput of eq then the output of eq to tape in play,then the tape out rec to the playback of eq then the rec out of eq to the phone imput on jvc .is this right.cause when I tried recordplayer out to eq line in,then the line out of eq to phone imput on jvc av it didn't work ,but the record player to the phone input on av works .I wanted to add eq to turntable to clear up the sound ...stop the little sound LPS make and and more tone .
Posted by Mike Kozlan on
Steve Pack
  • RCA Master
  • 6,349 Answers
Normally the turntable is connect to the amp via phono inputs on back (RCA connectors) the tape out to equalizer and equalizer out to tape in on amp. The equalizer does not have phono preamp. The equalizer may not clean up record scratches ,or pops or record track noise.
good luck
Posted on May 20, 2022
1helpful
How do I hook up a graphics equalizer SH-GE70 to the amp SU-A707? I've already plugged in the CD player SL-PG5 and the tape deck RS-TR474M2, but can't see how to wire in the graphic. If I could...
hi,
Try this. You need 4 RCA setreo Chord for this.
1. connect the cd player out to the LINE input of Equlizer.
2. connect the Record out of equlizer to Tape's Record input.
3. connect the Play out of the Tape to the Play in of Equlizer.
4. connect the Line out of the Equlizer to the CD input of amp.
Always Select CD in the amp. And select between tape and CD in the Equlizer.
OK
JVC RX-888V 5.1 Channels Receiver can not get the rear speakers to work at all. switched the wires from back to front and they work so the speakers and the wires are OK. tried to press all the buttons and...
If you can via experimentation confirm that your amps are ok then the issue lies with the Dolby IC chip that controls the various sound modes. It went on my Pioneer and I had hassles getting the various speakers to work properly under different sound modes. Replacement, not cheap, cured my issue.
JVC RX-888V hook up to cable box - no video
There is some sort of setting you need to change on the JVC receiver. I had this same problem, and I read the manual and it solved it. You need to press and hold down a button to change the mode. Your unit probably says "TV Sound" right now. Once you press this button (not sure what button) like the manual says, the display should change to "DBS" and then it should work just fne.
2helpful
2answers
User-manual Technics SH-GE70
Download instruction manual of SH-GE70 from Panasonic Support but you need to pay little fee to Panasonic.
1helpful
3answers
Technics SH -8058
the Technics SH-8058 is a beautiful unit, I got one myself for the past 20 years and never failed y EQuing the sound I want.
I am asuming, you got on your reciever TAPE MONITOR... well, the it is simple,
First, just forget about the TAPE on your Techincs SH 5058
Second, on your Technics LINE OUT, goes on your tape monitor LINE IN
and last; on your LINE IN, goes on your tape monitor REC OUT.
Now, choose you desire componet, and turn on your TAPE MONITOR on your reciever...
enjoy and have fun.
REQUIRE MANUAL TECHNICS SH-GE70
Try this link.
http://www.vintagetechnics.stereomanuals.com/equalizers/index.htm
Help
I have one but it is in Spanish! If want me to upload it here let me know..........
Technics eq sh-ge70
According to Panasonic the manual is only available for purchase (paper/CD-ROM) 1-800-332-5368
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
