How do I get firmware or a plugin for Zebra Symbol LS4278 Scanner - Model LS4278-SR20157ZZWR
I have this model Symbol Zebra scanner, and I am trying to set it up where I can configure it using 123Scan. When I check 123Scan, there is a message saying it is an unknown scanner. 123Scan shows an image of the scanner LS4278, but it says this model does not work with the plugin for LS 4278 scanners.
Is this some sort of specialized model that cannot use Zebra software, or is there something messed up with the firmware? I would love some guidance as to how I can get this scanner and others like it to work properly. Thanks!
usually you need to configure the reader to tell it what kind of barcodes you want it to read and how to interpret & output the codes to your computer (whether you need prefix or suffixes to your codes( for automation))
the user manual for the reader has some bar codes to configure the settings for the scanner.
It could be the scanner is not paired to the cradle. The scanner will be once for the barcode and then four times for the communication error. Make sure the cradle has power; it will pull power from a USB port. Scan the pairing barcode on top of the cradle. The scanner will give a high low high low beep and then shortly after give a short low short high beep indicating the radios have paired. If the scanner still beeps four times after doing this, the host type may not be set. If connecting USB scan HID Keyboard from the LS4278 Product Reference Guide.
There are three possibilities I can think of assuming this is not a brand new scanner:
1. The LS4278 is faulty - which given Symbols quality I would say it is normally not the case unless th scanner has been dropped or otherwise damaged.
2. The cradle is not charging the scanner. You may wish to try another cradle - one that you know is charging aother scanner. After a few minutes you should be able to see the laser.
3. The battery in the scanner either needs a recondition (see product reference guide), or needs replacement.
Hotmail is a service to send and receive email is no stranger to users. However, nowadays, most users use Gmail to send email and register many services on the internet.
Login to Hotmail is easy, just like logging in to Outlook Mail because both Hotmail and Outlook Mail are Microsoft's email addresses. So the sign up Hotmail account and Outlook registration is the same.
Hi, try scanning French Windows barcode from the USB section of the LS4278 Product Reference Guide. The barcode is on Adobe page 147 of 414. You may also have to scan the Enable Keypad Emulation barcode from Adobe page 150 of 414, but I would do this only after testing with the French Windows setting first. I suggest saving a copy of the document before printing the barcodes just to make it easier to print. Hopefully this will resolve the issue.
There is more setup needed and troubleshooting, please contact me so I can guide you how to get this scanner working You can always contact me by phone or email 630-622-2024 [email protected] Please visit our website www.legacyglobal.com
The scanner will probably give you error beeps because you are not using a PS/2 keyboard. All you should have to do is scan the IBM AT Notebook barcode from the LS4278 Product Reference Guide. The link below will take you to the manual and the barcode is on Adobe page 104 of 418. I would suggest saving a copy then printing just the page you need.
If the scanner does not start working immediately you should reboot your computer.
Hi, I would be happy to assist you in resetting your LS4278, but it would be helpful to know how you are connected. The Set Defaults barcode will reset all of the scanner settings, but it will also cause you to lose the "pair" (communications) between the scanner and cradle. If you try scanning a barcode at this point you will receive a single beep followed by four error beeps. This just means the scanner is not talking to the cradle. Scan the barcode on top of the cradle. The scanner should give a high low high low series of beeps followed by a short low short high. The short low short high indicates the scanner is talking to the cradle again and you are ready to scan.
If you are connected through the USB port and scan a barcode and get one beep, but do not see data on your host try unplugging the black power supply cable from the cradle. Try scanning your barcode again and it should show up on the host.
