Televison & Video Logo
Question about Hitachi Televison & Video
Hitachi M-171 VCR Turns on, but won't operate, tape inside,
I recently got a free Hitachi M-171 VCR. When testing was working ok, It took the tape in, blew a fuse and shut down. I put a new fuse in it. It powers on but does not do anything. Tape is still inside. Please help!
Posted by Justin Sterling on
We had just turned on the DVD/VCR and put a video tape in and before we started to play it. It powered off. Now when we try to turn it on it turns off again.
Did the tape remain inside the VCR after the power-off? if so, it is probably one of many causes including:
the power supply may have several short-circuit/leaky components within it, especially electrolytic capacitors and IC regulators;
if the VCR operates mechanically with more than 1 belt, chances are the belt(s) will need replacement (but not likely if the model is relatively recent, i.e. less than 5 years old).
Presuming the unit is idle, no tapes or discs in it, and it reverts to standby/clock by itself, without any action from you, then it would be poor regulation from the PSU.
Being a budget-model, the PSU should be pretty straightforward and not too expensive to fix.
3helpful
I put a vhs tape in an the vcr turns off by it self a green light keeps flashing by where it says cst in. I have a Hitachi DVD/VCR COMBO DV-PF2U. I also can not get the tape out
Unplug the power supply for thirty seconds and plug back in, this will reset the processor and might eject the tape. If this fails the next step is remove the top of the combo unit this will give access to the vcr tape, if the tape is spewed in the machine and wrapped around the video head and other mechanical parts use scissors to cut the tape and carefully removing the particles, press power to eject the tape for normal operation. However! if the vcr tape is okay, there may be a loading problem, broken drive belt, bad idler assembly to name a few, this is where a technician will be needed but may not justify cost.
The vcr stopped working, tape goes in but won 't work. the dvd stills works.
most likely a mechanical issue , look inside for anything laying inside the VCR section.
a piece of a label or a toy etc. if all looks well it could be a bad sensor , bad (dirty)mode switch
or sinply a jammed gear or arm.
a good way to check the VCR section is to turn the loading motor and see that it moves correctly
hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
1helpful
I put a tape in and I hear a loud clicking noise and the VCR doesn't play the tape and turns itself off after 8-10 seconds.
first, try another tape. if it does the same thing the vcr is out of alignment. many times a broken lever inside the vhs tape can cause the vcr to shut down.
JVC SR V101US won't load tape
most likely problem is defective loading motor. p/n VEM0427.
1helpful
2answers
HITACHI vcr DOES NOT LOAD TAPE
It's more than likely a slipping belt in the tape mechanism
If you are technically inclined it can be fixed for around $3.00
If you are not then it would be advisable to buy a new VCR because the repair cost would be more than the cost of a new one .
VCR kicks out cassettes
Sounds as if something got bent in the loading mechanism when you freed the stuck tape. Careful examination of the loading operation with the cover off may reveal the problem, but you may require a service shop, as there are hazardous voltages present inside, even when switched off.
Flashing "2" on VCR front panel.
Hi Oshaman. I have dealt with many VCR's and would like to ask you a few questions before diagnostics. How exactly did you get the tape out of the machine ? There are several tape threading gears involved, and if you accidentally made one of them skip a few teeth while forcing the tape deck up the "position" switch will send erroneus signals to the tape threading position switch/ controller. Was the tape rolled around the capstan/pinch roller ? Did you have to force the tape loading tray up to extract the tape ? Feel free to email me. [email protected] Happy Holidays.
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
