I recently purchased this fridge second hand, and immediately started having trouble. The fridge temp increased to about 8C (I keep a sensor in there). I realized that it was because the evap coils were freezing over and freezing the vent, so no air could get to the fridge compartment. I haven't been able to find a wiring diagram, but I inspected the circuit board and nothing looks damaged. I checked the defrost sensor. When defrosted it reads there is no connection. Then I turned the freezer back on and waited for it to freeze over again (took about 12 hours). Then the sensor reads 0 Ohm. So that appears to be working. I checked the seal on the freezer and fridge doors to make sure no moist air was getting in. They both seemed fine. I checked using the technique of putting paper in the seals, but I don't really know what I'm doing. The seals seem solid though. I also checked the defrost heating element. It read about 210 ohm, which seems fine. The only thing I can think of is the defrost timer, but I have no knowledge on how to check that.
Have you verified the evaporator coils aren't clogged up? If no airflow can get through the evap coils it can cause freezing.
Edit.
The defrost timer is usually in the toe kick area. You should be able to put a flathead screwdriver in it and turn it clockwise slowly until you hear 1 click- that is in defrost. Verify the heating elements are warming.
