Televison & Video Logo
Question about Toshiba Televison & Video
I just purchased a Toshiba MD14FN1 replacement remote. I am having trouble setting it up to be used on the tv.
Posted by Lauren Alexander on
Aron
    Top Expert:
  • Toshiba Master
  • 2,492 Answers
The remote may not be compatible with your TV at all.Or the remote might not work with your TV either.
Posted on May 20, 2022
How can you get to the menu on a Toshiba tv without a remote
If you do not have a remote for your Toshiba TV, there are a few ways you can access the menu to change settings or perform other functions:
  1. Use the buttons on the TV: Some Toshiba TVs have buttons on the side or back of the TV that can be used to access the menu or perform other functions. Check the TV's manual or the label on the back of the TV to see if this is the case for your TV and which buttons to use.
  2. Use a universal remote: You can purchase a universal remote that is compatible with your Toshiba TV. These remotes can be programmed to control your TV, and can be used to access the menu and other functions.
  3. Connect a keyboard or mouse to the TV: If your TV has a USB port, you can connect a keyboard or mouse to the TV and use it to navigate the menu and other functions.
  4. Use a mobile app: Some Toshiba TVs can be controlled using a mobile app that can be downloaded to your smartphone or tablet. This app allows you to control your TV and access the menu without needing a remote.
Changing language on Toshiba 32W24 TV from russian to english
How to Change Toshiba TV Language to English
Since the TV has been set in a foreign language, you might have trouble identifying what's written on your TV. In that case, you might have to take a note of the type and number of keys pressed in the below steps.
  1. On your Toshiba TV's remote, press the Menu button.
  2. Then press the Menu buttons on your remote two times. This will take you to the Settings page.
  3. Press the OK button your remote to confirm your selection.
  4. Now tap the Down button on your remote once to go to the Language menu and press the OK button.
  5. The first option will be the language selection menu and that will be selected by default.
  6. So just use the "Left" or "Right" button on your TV remote to English (or any other language of your choice).
  7. You may now hit the Exit button on your remote to close the Settings option.
1helpful
My remote control on my toshiba 32" tv stopped working or would work periodically. I have reprogramed the remote and changed the batteries 3 different times with same result. I purchased a remote ctl from...
A lot of times it is the remote sensor in the set. These are good sets so I would have it checked out. Could be fairly cheap. Thanks for using fixya.
I lost my remote and only need it to set the TV to channel 3 for cable. Is there any way to do this manually?
If you are able to access menu and channel setup, you can go into autoprogram and it will scan all available channels and store them.
Otherwise you can get a cheap universal or even original replacement remote
Television Shuts Off
TRY REPLACING THE REGULATOR OR CHECK DIODES IN SAID CIRCUIT ,ALSO CHECK FOR BAD CONNECTIONS.
1helpful
How to use Toshiba 32D46 32" TV with Comcast 3 in 1 Universal Remote Control
Most univ. remotes have a search mode if code entry won't work-
Do you have the comcast instructions ? Something like.....
1) Tv power on
2) Push set-up or program on remote
3)Touch tv button on remote
4) Point remote at TV and push power off. Repeat until TV turns off.............then
5)Push enter to save....
Hope I helped you........T.
3answers
TV does not respond to Remote
possible defective rf receiver led defective in the tv.
Remote signals
If you tryed a universal remote , that remote should have at least worked the volume and the channels selector. It could be whats called a remote sensor assy thats mounted up toward the front of the set on the inside between the buttons. Its not really a user changeable part as there is soldering involved to replace the sensor. Realisticly, the correct way to trouble-shoot this set is to look at the data or logic line coming out of the remote sensor with an osilliscope to see the data and if it goes all the way to the microprocessor IC. If it does and no remote operation happens then the Micro's bad. Theres way to much Hi-voltage in these sets for a handi-person to tinker with, and its advised that a tech take a look at this set for you . Sorry I couldnbt be of more assistance. Good Luck
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
