Dryers Logo
I
Ilka Posted on May 15, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whats means SRU and CLL message in Kenmore Dryer?
Serial 4D14400321
ADMIN Andrew
Level 3:
Top Expert:
  • Kenmore Master 66,749 Answers
  • Posted on May 15, 2022
ADMIN Andrew
Kenmore Master
Level 3:
Top Expert:
Answers
66749
Questions
Helped
5044815
Points
378605
The serial number is just a numerical reference of when it was made. The Model number is the import part.
Kenmore dryer will run for approximately five minutes. It then stops and throws a CLL SRU error code. I have researched this to mean "Call for Service". I have seen others potential causes that range from shorted heating element, to dirty lint screen/venting.
CLL SRU Error Code ' Appliance Video
Video as well
https://www.google.com/search?q=Kenmore+Dryer+SrU+and+CLL+error+message
How do I clear a cll sru code on my 2014 kenmore elite washer to test it . Or will it clear itself if I fixed the problem?
I would unplug the machine for about half hour this should wipe the fault codes from the machine.
The dryer comes up with 2 codes CLL and Sru. It functions fine, can I continue to use it for a few days until the service rep can make it?
Clean the lint filter and shut down the machine for 5 minutes. Restart and see if the codes clear. If no problem, no worries, just ignore the codes.
I have a kenmore elite dryer that is only 4 yrs old. It stops about 5 minutes into the cycle and puts up 2 codes. CLL and Sru what do these codes mean and can I continue using the dryer ?
Clean the entire exhaust duct from the back of the machine all the way out of the house, if the codes don't change. Call a service tech... CLL SRV = call for service
Kenmore elite dryer have error code cll sru? How to fix it and what is wrong
Most likely a broken wire in the dual heating element. Pull the cover off the machine, with the power cord unplugged and put a voltmeter on Ohms checking for continuity of the elements. Also check the overheat fuse(s) for continuity.
Check for clogged or restrictions in the exhaust vent. I had a bees nest once on the outside which restricted the door on the vent from fully opening, which lead to an overheat condition.
Kenmore Elite washer service code CLL SrU
Re: Kenmore Elite 417; error CLL SRV We have well water and I think my error message and locked door were because the machine was trying to plump water and not getting any. I heard the error beeping and sent to check it out. There was another noise that didn't stop even after unplugging the washer, although the beeping did, which finally stopped after I turned off the water valves. Press and Hold the power button down to unlock the door and retry. If you still have trouble, call for service.
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
