Dishwashers Logo
Question about Miele Dishwashers
Miele G4970 dishwasher soap lid is not opening
I have a Miele G4970 that has been operating perfectly for about 3 years. Recently, the detergent door has stopped opening at the appropriate time during the wash cycle. I listen for the solenoid, then open the dishwasher door and manually release the door and the soap pod. The spring is fine since the door snaps open when the release button is pushed. I'm not sure why this is happening, but of course, I need to fix it. Anyone have any ideas?
Posted by Bocaboy on
Soap door not opening
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
1helpful
I have a Hotpoint HDA2100 and I am having an issue with the soap dispenser. The lid is not opening all the way during the cycle. When I open the door after the cycle is complete to remove my dishes, i...
heatman101
Detergent tray doesn't open during operations.
heatman101
1helpful
My office's GE QuietPower 3 dishwasher detergent
heatman101
1helpful
The washing powder dispencer door will not open when washing
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
heatman101
2answers
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 • Dishwashers
Dishwasher detergent door won't release soap
heatman101
l
1helpful
Do you have a meile g892 dishwasher?
Yes,
a G892SC - for over 6 years now. It's so quiet that many a time I've opened the door to put something in it, only to discover it'd been running (rinsing, etc., not drying!) the whole time! Despite 3 years in the Army and lots of Rock concerts, I have no hearing loss ;-)
One year ago, the little orange plastic detergent lid latch broke. And considering how well-made the rest of the unit is, it was not as robust as the rest of the DW. I Emailed Miele, and they sent out a repairman who replaced the entire soap unit on the door for FREE, even though it was well out of warranty. You pay more, and you get more.
Brad Wolff
1helpful
2answers
Dishwasher problem
Symptoms:
Dispenser lid is open. Caked powder at (what would be during normal operation) bottom edge of soap dispenser or caked powder fallen onto dishes or dishwasher bottom. There may be loose powder in rest of dispenser or spilled down inside door or onto dishes underneath dispenser.
Solution:
Keep the area around the soap dispenser lid clear when loading the top tray.
Explanation:
The soap dispenser needs to swing open during the wash cycle. In many dishwashers the top tray has an indentation as wide as the lid of the dispenser. This allows the top tray to be as large deep as possible while still allowing space for the dispenser lid to open. People often pack their dishwasher with things overhanging this gap.
During the wash cycle the catch will release but the overhanging cutlery or crockery prevents the lid from opening all but a few degrees. Some water will splash in but not enough to wash out the soap powder. The soap powder at the bottom of the dispenser will then cake.
When the front door is opened the spring loaded lid, which is partly open, will of course swing fully open and you'll be convinced that the lid opened normally during operation. If this is the problem then if you're very careful and open the door very slowly you can actually hear the lid flip open. Also, depending on when the lid opens, how far it opened during operation and how fast you open the door you may find soap powder spilled down to cover the dishes at the front or down the inside of the door. This happens when you first open the door and obviously there couldn't be loose powder there if the powder had emerged while there was water washing around. Seeing the lid open as you open the door is a lot harder but can be done on some machines.
1helpful
2answers
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Top Miele Dishwashers Experts
David Shaub
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
