Microwave Ovens Logo
Question about Panasonic Microwave Ovens
How to fix the display lights from going off when I close the door?
Panasonic Inverter NN-SN7975 serial 6F53241069 When I close the door, it turns the display lights off. If I keep opening and closing the door it eventually lights up again as if I was turning it on for the first time. Thank you for your help.
Posted by Christine E Speight on
Larry Ng
    Top Expert:
  • Panasonic Master
  • 13,158 Answers
Do mean the LCD or plastma graphic display goes 100% dead
when door is closed, and not cooling
mine shows TIME there,
page 12 in your manual
unplug Uwave from AC wall jack for say 30 minutes
plug back in and he display asks for time, it must and was lost above.
myGE WILL NEVER WORKs If TIME AND AM/PM ARE NOT SET first.
THIS UWAVE HAS CHILD LOCK FEATURES. and more oddities,
HERE IS THE FREE MANUAL
https://www.manualsdir.com/manuals/453553/panasonic-nn-sn797s.html?page=12
AND PAGE 13 ALL OFF THAT page (settings)it EVEN sets CLOCK OFF odd demo modes and more, read it all.
IF KIDS PLAYed HERE, THERE ARE MANY THINGS THERE TO GET WRONG ,SO PULL THE AC CORD, FOR 1HR OR MORE. IF IT FAILS TO RESET, LIKE PULL ac CORD OVERNIGHT,.
gOOD LUCK. (yes way over too complex)
Posted on Aug 21, 2022
Panasonic inverter microwave nn-sd688s, stops and resets but then will work again after, seems to do this just by opening and closing door. What could be the problem?
I'd check the door switches to make sure they are being reliably activated when the door is closed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Panisonic inverter microwave lights up but doesn't fully come on
How to fix microwave that counts down but does not heat or ...
? 4:51
https://www.youtube.com/watch?v=PIU1NRpeA_8
Oct 2, 2012 - Uploaded by G-Unit_YouTuber
How to fix frigidaire microwave door sensor relay switch. ... with a different part number (D3V-16G-2C25) but it doesn't look like it's stocked. ... Problem now is that when we open the door, themicrowave comes on by itself! ... I am not sure, when you hooked up the volt meter, did the lights turn on and off ...
All comments on Fixing Panasonic inverter microwaves ...
https://www.youtube.com/all_comments?v=hBJJU4ZRh7U
i have a nn-h965wfx the light comes on the countdown initiates but nothing comes .....I have a similar full size panasonic inverter microwave NN-L931BF built in ..... After putting it all back together the thing doesn't even power up the display.
Panasonic 1200W 1.2 Cu. Ft. Countertop Microwave Oven ...
www.amazon.com/Panasonic...Microwave.../B005BFZ...
Amazon.com, Inc.Ft. Countertop Microwave Oven with Inverter Technology NN-SN661S Stainless at Amazon.com. ... The microwave panini meals even end up with toasted crisp bread. ...But, right now, I find the interior light functionality just fine. .... (1) In this Panasonic, the light doesn't come on when the door is open; it only comes on when ...
1helpful
2answers
I have a Panasonic microwave. It is Model NN-T774SF. It has an inverter. The latch on the door will not close. Is it worth the cost of repair?
This is usually a pretty simple fix.
The spring has probably become disconnected from the door latch head assembly or inner door panel.
If so, you can either order a replacement for the broken part, or install a small screw into the broken part, reinforce it with epoxy, and then reassemble everything.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the parts involved.
Or you can watch a
YouTube video (not a video I made) that demonstrates how it's done.
Our Panasonic NN-S763BF microwave turns on (light goes on, table turns and fan goes on) automatically when we open the door even though the clock is displayed. It works normally when the door is shut....
You have a faulty interlock switch (which the door operates).
This needs to be renewed by a qualified microwave service technician ASAP.
A potential hazard if not fixed immediately!
My micro oven NN-C2000P No lcd light display even the 240 v suppy is going in the Power supply panel. the door is totally close.
IS GREEN LIGHT IS ON BEHIND LCD ? ANY LCD NEEDS BACKLIGHT TO DISPLAY. JUST LOOK OUT FOR FUSED BACKLIGHT. LET THE DOOR OPEN OR CLOSE THE DISPLAY SHOULD BE ON.
I have an nn2505c microwave that powers up but displays door open
Took it to a repair shop ,cannot be fixed ,no parts discontinued microwave.
Nn t993sf
Sounds like the door switches are out of adjustment or broken.
I would take it to a shop for repair. Microwaves are almost always repaired affordably unless it is really old.
Hope ya fix it!
Top Panasonic Microwave Ovens Experts
Jaime Hernandez
Paul Bade
Steve
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
