Need instruction on how to adjust carberator
Adjusting carbs on chainsaws is not to be taken on lightly, there will normally be three screws, an L screw, an H screw, and an idle scre, the L screw will increase the fuel mixture from idle to half throttle ( they are fuel screws not air screws ) the H screw will adjust from half throttle to maximum revs, start with a base setting of between one turn and one and a half turns out, start the saw and warm through, allow it to idle, if need be increase the idle screw to get an idle, turn the L screw in slowley, the revs will increase as the mixture leans off, it will reach a point where it starts to die, now back it off a quarter of a turn, blip the throttle, the saw should pick up clean, if it has a flat spot increase the L screw slightley, now set the idle so it idles without the chain moving on the bar, now screw the H screw in to get full revs, be aware this should be set with an engine rev counter, do not exceed the manufacturersmax revs, hobby saws normally run at about 12500 rpm with an idle speed of 3000 rpm.
