https://www.fixya.com > Forum > Radio Communications
Some radios have phone buttons that mute the speakers so you can talk on the phone. If you have Onstar and no active subscription it can also mute the radio ...
Playback will paused if the system is muted. If the steering wheel mute control is pressed again, playback will resume.
If the source is changed while in mute, playback resumes and audio will unmute. I'm sure you checked the wire to fuse, and have made sure no other speaker wires are grounded, to each other. You can do a hard reboot to your stereo. By removing the main fuse that controls your computer chip. Once that has been done your vehicle will go back to factory settings, and you will have to go save your favorite stations all over.
Walld"
Mute Microphone
With the handset
You can temporarily turn Off the microphone so that the person you are talking with cannot hear you.
1)Press menu/del during talk mode (while phone is in use).
2)Press ring/vol/? or ring/vol/? to move the pointer to Mute and then select/
Mute On and appear in the display. To cancel muting, repeat above step again when Mute
is set to on, Mute Off appears.
With the base
While using the base speakerphone, press mute on the base to turn Off the microphone.
Press mute again or press (speaker) to cancel muting.
The sound of the dial pad can only be adjusted with the silent/mute button on the top left of the phone. If it is switched to silent then the dial pad will make not make sounds, if it is on loud then it will make sounds. There is no other way to adjust the sounds of the dial pad.
go to the sound option down to the right side and click on to sound icon and unmute it or go the control pannel and then go the soung settings and unmute it ....
navigate with the monitor buttons to the OSD (on screen display). menu button brings up the OSD. then use volume buttons to move around. there should be a mute option or indications by symbols how to unmute the sound option. if there is not, i would guess pressing two buttons at the same time might do it.
