Question about Toshiba 32A33 32" TV
All works on tv but picture is very dark no matter what you do
Posted by vankleeck74 on
Anonymous
  • 26 Answers
If the brightness control has no effect, then picture tube is going out if it has a glass tube crt display. used to be a rejuvinator would cook off some of the deposit internally on the crt, but it also reduces the life of the set.
Posted on Sep 21, 2009
Our tv is very dark. The picture can barely be seen. How do we fix that?
how many hours did your lamp work? perhaps the lamp need to be replaced.
if it was new lamp. the other two possible reason is light tunnel and ass relay.
no matter for what reason, you need to clean it for so old model tv
Screen is really bright on dynex dx-l42-10a. Still show picture but bright no matter how it is adjusted. Was fine while watch TV & picture just got bright like the darkness quite. Any suggestions & what...
Sounds like screen voltage has exceeded much. Its LOT adjustments should be checked. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Why is picture so dull?
There are two reasons for this. Back light problem, and T'Con board problem. It will be best to contact any service technician. Gopakumar Gopalan Google
My mitsubishi 72 inch tv has gotten a very dark picture. What can I do to fix this?
adjust the color go to the menu and change the color meter to darker or lighter and your welcome
Sony tv kdl-46vl130, Turn the tv on, half of the picture is dark, leave the tv on for about 20 minutes, and the tv is perfect, and stays perfect no matter how long is watched, Turn the tv off, and come...
I didn't look up the model to see if its a LCD or LED, if its an LED it sounds like you have some lamps going out, try turning down the backlight settings and see if that helps
Picture's too dark no matter how much i turn the contrast or picture up its still too dark
Looks like picture tube grid +dc supply. Check the resistors on the picture tube neck PCB.
Colors on the tv are dark
the screen control on the flyback transformer needs to be turned up a little
1helpful
2answers
Dark Picture
Symptom: NO PICTURE
Cause: DEFECTIVE 3D/YC COMB FILTER
Symptom: DARK PICTURE
Cause: DEFECTIVE C724
2answers
Picture is dark
Does not seem like a bad tube alone. Could also be that the Video output Transistors Supply Filter capacitor having dried out. It is a 100mfd 160V capacitor, which on replacement will improve the brightness of the immage. And yes, you could also try increasing the heater voltage (Filament Voltage)of the Pictuire tube, this will definitely increase brightness, but will reduce the life of the Picture tube. You gotta think - 10 year old TV, should I repair or exchange and get a new one???
Toshiba 32A33 32" TV Logo
Top Toshiba Televison & Video Experts
Ekse
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
