The VE1020 didn't come with a mount. It came with round plastic spacers (16) that were 1/4", 1/2", and 3/4" thick. You could stack these on the mounting screws to get the clearance you needed for under the cabinet mounting. You will note that there are 4 through holes for the mounting screws, one in each corner of the chassis. Sheet rock screws of different lengths will work. You can easily just cut four small blocks of wood or use 3/4" - 1" wood dowel cut to the length you need. Drill a through hole in the dowel. Paint them to match if they will be exposed.
Sounds like it could be a bad inverter for the screen lamp. If it is a bad inverter and the tv is still under warranty you should send it back for a replacement or repair. If the tv is not under warranty and you have some experience working on electronic devices you could probably find a replacement inverter online and replace the bad one.
There has to be a small hole at the front of the door where u will be able to insert a paper clip and press then dvd shud eject. If not open door with a paper clip and manualy pull the drawer outwards, though be careful and do it slowly thus not damaging the gears of the ejection system. hope it helps. regards.viv
