NEED to get inside will not open
This will almost Certainly open your case.
http://support.gateway.com/support/manlib/Desktops/8508752/index.htm
The first link below gives detailed instructions; you have remove the base first, then a retention screw, then there is a release latch (the instructions include pictures).
To get general support for your specific system, visit the second link below (the above instructions were found by clicking "My Support Documents", clicking the "Support Docs" link next to Nina Micro ATX Case [under the Cases and Case Hardware section], and clicking "FAQs").
Good luck! :-)
Source(s):
Gateway Support - FAQs - "How do I remove and replace the case panel on a Nina case (open the case)?"
http://support.gateway.com/s/CASES/35012…
Gateway Support - My Product Info - Gateway 300SE
http://support.gateway.com/support/allsy…
This guy describes how to do it
http://answers.yahoo.com/question/index?qid=20071009091436AA4QVTG
Hope it helps :)
SOURCE: How do I open the case on a gateway (GM) MFATXNIN NMZ 300L ?
There's a security screw on the back that needs to be removed to allow the front latch to release the side panel. It's the stupidest most confusing case ever. The latch is very hard to see, it's part of the black plastic in the front, just push down on things until you see one move a bit. It's sort of like a car door handle movement.
SOURCE: RAM upgrade for Gateway model MFATXNIN NMZ 300L?
The system takes PC133 SDRAM, as far as i know without performing a BIOS flash it can take up to 1GB (2x512MB) most of these PC's are restricted to 2x256 so a BIOS flash could be imminent in this case.
Good luck
SOURCE: gateway mfatxnin nmz 300s no power
sometimes they just die the windings burn out in hidden spots and trust me i took 1 apart to find the burn it's not worth the time just to have a look
spend the cash and buy a universal adapter
just rember voltage and amp or mily amps required
SOURCE: need manual for gateway mfatxnin,
http://support.gateway.com/support/manlib/Desktops/desktop.shtml i found it on here but it wont let me link directly to your model
get in wat
Sir, Please provide Brand Name and Model Number.? Thanks Good Luck
