Question about Teac Audio Players & Recorders
My TEAC AVR 21G doesn't power ON. What might be the problem please?
Posted by edwin atanda on
ADMIN Andrew
    Top Expert:
  • Teac Master
  • 57,206 Answers
Sharp X FLAT SLIM Model - 21G-FX10N need FBT number
try to look for this manual..
https://manualzz.com/doc/1102543/sharp-21g-fx10la-service-manual
tip
Make it fasterrrrrr
use the beverly 400cc rolls i think 21g. result is something perfect!! I buy malossi multivar for nexus 500cc and i get with it 15g rolls witch wasnt good because rmp was to hi (screaming in empty space) but with 21g rolls your engine power will be used on the perfect gear ratio.
on Dec 26, 2008 • 2005 Gilera Nexus 500
Is teac avr 21g a power amplifier or just an amplifier
I think you are getting confused between an amplifier and a pre-amplifier.
The AVR 21g is an amplifier, which will have a pre-amplifier built into it.
A power amplifier is an amplifier. It has the ability to drive speakers. However one on it's own, you can't connect tape decks, record players or any device you want to listen to.
A pre-amplifier doesn't have the ability to drive speakers. But you can connect devices to it.
As the device you are asking about is a audio video receiver (AVR) then it will have both amps in it.
Some of this type even have the ability to have both amps separate.
I have a Kenwood VR-507 trying to hook up Teac EQA-120 Home Equalizer
As with any stereo analog device, processor or tape deck - Outs go to Ins. But any typical AVR will only be able to use it for analog stereo sources. Once a Tape Loop is engaged all digital inputs are disabled though you CAN still use DSP effects on the analog sources.
Is there anyplace that has denon schematics listed for free. I need them for models, AVR-4308CI & AVR-2307CI. Thanks, Lynne
send me your email address to [email protected] and will email you them tomorrow,, put in title models make required to avoid spam..regards..yammandan.. have all teac denon yamaha manuals...regards yammandan
Connecting An Equalizer
you will need 6 equalizers or 3 stereo equalizers.
connect the 5.1 analogue outputs of your media player (DVD Player) to the equalizer and then connect the analogue output of the equalizer to the AVR.
now you can equaize the sound for extra boost and cut.
Warning: it is not recomended to do so unless you have a powerful amp and high quality and higher wattage speakers, as equalizers are ment to be used mainly for entertianment zones and outdoors in professional applications.
the home speakers annd electronics are not really capable of taking such electronic stress as they are designed to work indoors in a confined space.
but if you are confident go ahed.
2answers
My TEAC PL-D2100 home theatre system, is not showing all natural colors in display since yesterday.
the red rca jack of the component output on your dvd player or the red input on the Avr component input is not plugged in properly ( loose ) or the the component monitor out to the tv may be loose. there is also possablity of cable cut. check it with another component cable or interchange the red to green to find if the problem perssts ,... to ascertian weather it is the cable.. this info should solve your prob.
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
