Garden Logo
Question about Husqvarna Garden
How do I adjust the carburetor on a Husqvarna 525LS and Husqvarna 128LDX weed eaters please?
Posted by Joe Russell on
ADMIN Andrew
    Top Expert:
  • Husqvarna Master
  • 53,121 Answers
Question edited for clarity.
There are videos in this link.
https://www.google.com/search?q=adjust+the+carburetor+on+a+Husqvarna+525LS+and+Husqvarna+128LDX
Posted on Apr 21, 2022
  • Joe Russell Apr 22, 2022
    the weedeater will started up and run and sometime it run a little fast then another time it want idle i did some adjustment on the carburetor and clean the carburetor out and it still doing the same thing do i need a new carburetor?
  • ADMIN Andrew
    ADMIN Andrew Apr 22, 2022
    Hi Joe
    I didn't realise this question was yours!
    Yes that behaviour sounds like they are worn. As long as you stripped them and cleaned all the jets, replaced any seals and o-rings? After that they should run sweet. When you remove mixture screws, always screw them fully in first until they gently come to a stop. Count how many turns, say 2 1/4. That gives you a chance when you put them back in to get the mixture right. Manuals normally say something like 'Idle Mixture Screw 2 1/4 to 2 1/2 turns out.
How to adjust the carburetor
What type of carburetor are you trying to adjust? two cycle, 4 cycle? Is it on a weed eater or lawn mower? This will be helpful to find the right answer that you want.
Oct 19, 2017 • Garden
Husqvarna 128LD weed eater wont start - replaced card - sparl plug - getting gas - ???
check your piston for scoring, Check ignition coil and your spark assessor screen inside your muffler. If that doesn't work replace your carburetor. I have one of those and had to buy a new Cylinder& piston kit after 2yrsa because the Piston was scored. Cheap junk. Mine runs good now.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/anthony_e4f197748c31eabd
Husqvarna 128LD weed eater wont start - replaced spark plug - carb - ????
If you can confirm that you have spark then you basically have a fuel delivery problem - carburetor.
If you installed a new carb you have to set it up , with the idle adjustment , and the low and high speed mixture screws. You just do not insert the carb and expect it to work.
My Husqvarna 324LX. Weed eater, Does not run well, Can I Adjust the Carpurettor
If it was previously running well, then the carburetor will not need adjusting, but it may need cleaning. If you have never done this before, take it to repair centre.
1helpful
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
2helpful
When i start my husqvarna weed eater it has no throttle response...what can cause the problem
A clogged fuel system or a carburetor in bad need of a rebuild can cause this. Also, if the engine end of the throttle cable has pulled out of the lever on the carburetor, or off of the trigger on the handle, you will have this symptom.
13helpful
6answers
My Husqvarna 128 LD bogs down and quits running
Dirty air filter, dirty fuel system, ie carb, lines, fuel tank. Poor air fuel mixture srew adjustments.
Craftsman weed eater wont run
MAKE SURE YOU REPLACE THE CARB GASKETS. ALSO MAKE SURE YOU ARE USING FRESH FUEL WITH THE RIGHT MIXTURE. COMPRESSION SHOULD BE AT LEAST 90LBS
Sep 24, 2009 • Garden
Open Questions:
0answers
Blades engaging intermittently/surging: Husqvarna zero turn Z246, Kaw FR600V AS 18, Hello there, Need expert advice please. I ran over a garden hose the other day and v belt and tension spring came off. Couple of hours mowing next day no problem, until belt slipped and spring came off again (ran out of juice and mower stopped just before this). I know, I'm hoses and fuel challenged but it had been a long day :) Reattached spring and threaded belt again and blades engaged. Blades ran at normal speed while stationary and then started intermittently loosing power and surging back to full speed at different time intervals while mowing at different heights of deck and lengths of grass. I can't establish a pattern, seems random. Tested PTO switch all good, tested earth all good, tested resistance on clutch all good, fuse all good. Did find left side lever safety switch was loose and wondered if this could be the problem. Tested switch for continuity, all good. Tested also while running by engaging blade and wiggling Left side lever to see if loose safety switch could be causing clutch to surge on and off and slip the belt due to the vibration. I will order a new belt tomorrow and try that, guessing old belt may be stretched despite increasing the tension. Hopefully it will run as normal with a new belt, but I think there might be an electrical fault somewhere and I'm hoping someone may have some ideas for me. Please note, this is my first multi meter ever and the breadth of my electrical/mechanical knowledge is close to zero, so please advise in lay terms. TIA, Amanda
Top Husqvarna Garden Experts
Dwain Pippen
Jay Finke
Jay Finke
Marvin
Marvin
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
