Here is some great PRINTER solution by Some FIXYA EXPERT. Get any kinds of PRINTER solution from bellow.
» Lexmark Printer Solution
» Epson Printer Solution
» Brother Printer Solution
» Dell Printer Solution
» Canon Printer Solution
» HP Printer Solution
» Kodak Printer Solution
17Here is some great PRINTER solution by Some FIXYA EXPERT.
17
You can't post conmments that contain an email address.
Please note that the #2 cartridge is the starter cartridge and the after market cartridge is the #1 cartridge.
The Lexmark X2470 printer uses the #1 cartridge which prints both color and black accordingly. While printing black it uses processed black. Hence, to print color images in "Black Only," please follow the steps given below:
1. Click on "Start," "All Programs," "Lexmark X2470 printer" group and then "Lexmark Photo Editor." 2. Click on "File" and then "Open" to select the color image file. 3. Click on "Image," "Mode" and then select "Grayscale." 4. Click on "Print."
This will print the image in gray.
Good day Sir, I suggest use the Solution Center. to open click start - programs or all programs - Lexmark Solution Center. find the maintenance tab. Maintenance tab help you install print cartridge and troubleshoot other ink problems.
reinstall the cartridge. Turn of the printer leave it for 10 minutes and restart again. If you still have more problem check below link, youmight find some useful info. http://pc-and-peripheral.blogspot.com/
Changing a print cartridge
Removing a used print cartridge
1 Make sure the printer is on.
2 Lift the scanner unit.
The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
3 Press down on the lever to raise the cartridge lid.
4 Remove the used print cartridge.
-take out your cartridges and put it back in again after 5 minutes. -print an alignment page and you have to scan the alignment page that you printed -try to print
17
