Dishwashers Logo
M
MICKEY Posted on Apr 19, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to locate, access & clean the trap in Electrolux Dishwasher model # GLD2440REC1
The dishwasher is several years old and has started to have a foul smell whenever it's turned on. The smell does go away as it runs so I'm assuming it's the trap. Problem is I can't seem to figure out where it is and or how to remove to clean it. Any help would be appreciated. Mickey
ADMIN Andrew
Level 3:
Top Expert:
  • Electrolux Master 66,772 Answers
  • Posted on Apr 19, 2022
ADMIN Andrew
Electrolux Master
Level 3:
Top Expert:
Answers
66772
Questions
Helped
5047776
Points
378732
Run a long, hot, bleach wash. A couple of cups of Javex should do it.
https://www.google.com/search?q=clean+the+trap+in+Electrolux+Dishwasher+GLD2440REC1
  • 1 more comment
  • MICKEY
    MICKEY Apr 19, 2022
    I'll check out the url you included and try cleaning with bleach. Ran baking soda and vinegar through it a couple times.
  • ADMIN Andrew
    ADMIN Andrew Apr 19, 2022
    Baking Soda and Vinegar doesn't do much because by adding an acid (vinegar) and an alkali (baking soda) together, they just make bubbles of Co2 and revert back to a neutral solution that is neither acidic or an alkali. You would be better off with 'WASHING soda' rather than Baking Soda, but not mixed with anything.
    Washing Soda and Baking Soda are both alkaline (basic). Baking soda has a more neutral pH of 8. Washing soda is more alkaline with a pH of 11.
    Aug 27, 2016
    https://brendid.com/difference-washing-s...
  • MICKEY
    MICKEY Apr 19, 2022
    Andrew great advice! Thank you for sharing. I followed the vid on the url, ran the bleach and the smells gone! I'd recommend fixya's url to anyone including my own readers. Have a great day and stay safe.
How to replace the bottom door seal on a Electrolux Dishlex dishwasher DX303WK
How to replace the bottom door seal on an Electrolux Dishlex dishwasher DX303WK.
To Note: Before you begin, make sure you have the correct door seal for your dishwasher model. Before beginning any repairs, switch off the dishwasher and unhook it from the power source.
Materials Needed:
  • New door seal compatible with Electrolux Dishlex DX303WK
  • Screwdriver
  • Pliers
  • Clean cloth
Step 1: Remove the Old Door Seal
  • Open the dishwasher door and locate the existing door seal around the bottom edge of the tub.
  • Gently peel back the old door seal from the edge of the tub. It should be secured with a rubber gasket or clips.
  • Use a screwdriver or pliers, if necessary, to remove any retaining clips or fasteners holding the old seal in place.
Step 2: Clean the Area
  • Once the old door seal is removed, clean the area around the edge of the tub thoroughly. Use a clean cloth to remove any dirt, debris, or residue.
Step 3: Install the New Door Seal
  • Take the new door seal and align it around the edge of the dishwasher tub, making sure it sits properly in place.
  • If your dishwasher has retaining clips or fasteners, use them to secure the new door seal in place. Alternatively, press the seal firmly to ensure it adheres to the tub securely.
Step 4: Test the Door
  • After installing the new door seal, close the dishwasher door gently.
  • Check for any obstructions or misalignment of the seal by running your fingers along the entire perimeter of the door. The seal should be evenly and securely in place.
Step 5: Reconnect and test the power.
Connect the dishwasher to the power source after ensuring that the new door seal is correctly placed.
Run a brief cycle or just check for leaks while the dishwasher is running normally.
If you run into any problems or difficulties throughout the replacement procedure, review the dishwasher's user manual or call Electrolux customer service for assistance. Additionally, if you are unsure about replacing the dishwasher yourself, consider hiring a professional dishwasher repair service.
How to remove large food particle trap in a electrolux dishwasher model # EWDW6505GBO
Good Morning Friend,
I understand you want to know how to remove large food particles that are trapped in your Electrolux dishwasher, model# EWDW6505GB0. First, I would suggest that you scrape away large pieces of food before putting any dish in your dishwasher.
Your dishwasher is equipped with a state of the art wash system. Periodically, the Glass Trap Filter and Large Food Particle Trap may need to be cleaned to maximize wash performance. The Glass Trap Filter is located in the center of the Large Food Particle Trap. The Glass Trap Filter is designed to collect pieces of broken glass, straws, bones and pits. To remove items in the Glass Trap Filter, grasp the handle, lift out, empty and replace. Hope this is helpful.
-Best Regards-
WP
I have a electrolux dishwasher. Non of the buttons will function and the display is stuck on clean.
Hello louisewith4 - I understand none of the buttons functions on the dishwasher, however try unplugging the unit or flipping the household breaker off. Wait approximately ten minutes and I suggest touching each button individually on keypad, does the display change or will it start? If not, I would recommend contacting a professional because the unit may possibly have a defective keypad.
1helpful
Cleaning the trap
The soap trap and its cap covers the soap in your dishwasher after you fill it and then swings open to dispense the soap when the wash cycle starts. If your dishes aren't getting clean or you notice the soap trap door is still shut after the dishwasher finishes a load, it may indicate a problem with the soap trap you'll need to fix.
Instructions
Things You'll Need:
  • Dishwasher soap cap replacement,Screwdriver,Multimeter.
  1. 1 Open the lid of the soap trap and clean out any leftover soap. Soap and detergent, especially the inexpensive brands, can clump together and harden inside the soap trap instead of releasing into the water during the wash cycle. Change to a different soap and run the dishwasher again. See if the clumps disappear and if this solves the problem.
  2. 2 Remove the old dishwasher soap trap cap and replace with a new one. The plastic cap should slide or pop off. The instructions for the new cap should instruct you how to slide or pop it back into place. A new cap may solve the problem if the cap is not opening during use.
  3. 3 Turn off power to the dishwasher by either turning off power at the circuit breaker panel box or moving the unit out from the counter and disconnecting it from the power supply. Always do this when working inside the dishwasher to avoid electrocution.
  4. 4 Open the dishwasher door and remove the screws to take off the front paneling. Leave the screws holding the bottom hinges to the door in place to keep the door itself from falling off. Depending on your model, you may need to remove some clasps as well. Your goal is to gain access to the inside of the door and control panel so you can see the different knobs and buttons, and can fix the parts controlling the soap trap.
  5. 5 Locate your soap trap. Close the soap trap cap and insert a screwdriver to push on the metal piece -- called a bi-metal switch -- connected to the soap trap cap until the cap swings open. If the metal looks out of place and the cap doesn't swing open like it should, push the metal back into place with the screwdriver and try again. If this does not fix it, remove the metal piece and replace with a new one.
    If you can't find the metal piece, your dishwasher may use a wax motor assembly instead. Located near the soap trap cap, it's typically a small red or maroon colored plug with a small black rod sticking out of the end. Remove the wax motor for testing if you don't have a bi-metal switch.
  6. 6 Locate the round timer motor inside your dishwasher. Refer to your dishwasher's instruction manual for help identifying the different parts. Typically, the timer motor is a round piece with holes in it, and may be located near the timer control on the dishwasher itself. Remove the timer motor from the dishwasher.
  7. 7 Test the timer motor and wax motor assembly using a multimeter .Choose one of the motors to test and place one probe from the multimeter to one wire of the motor and the other probe to the other wire. For the timer motor, Part Select.com suggests setting the multimeter to the "x1000" ohms setting and you should get a reading of 2000 to 3500 ohms. If your reading is significantly different, the part is bad. For the wax motor assembly, set to the "x1" ohms setting and touch the probes to the wires. If the screen shows the infinity symbol, the motor is bad. Replace either part as needed.
HOPE THIS HELP?
Thanks.
Nov 06, 2010 • Dishwashers
No water?
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Jul 24, 2009 • Dishwashers
Not enough water Pressure to clean dishes, 6yr old Bosch
Replace the pump, if you go through the trouble of repairing the pump and all the disassembly and then more problems will probably ensue. As far as location it is usually located under the washer. Accessed through the front service panel. Make sure you follow all safety procedures #1 being unplug the washer or turn off breaker prior to proceeding.
24helpful
5answers
Top Electrolux Dishwashers Experts
Mike Cairns
Mike Cairns
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
