Televison & Video Logo
Question about Toshiba Televison & Video
Where can I get a service manual for a Toshiba 37RU530U TV
Looking for the cable connections from the logic board to the power supply board
ADMIN Andrew
    Top Expert:
  • Toshiba Master
  • 57,424 Answers
Larry
  • Toshiba Master
  • 4,816 Answers
Service manuals for most LED TV's aren't available, according to tech support at several major brands they don't have one either, just a flow chart, manufactures want to sell new sets verses fixing them
Posted on Apr 15, 2022
Testimonial: "Thanks all… it is a hobby to fix broken stuff. I bought a used power board on eBay, not getting all the standby voltages. Hopefully I can return it."
  • Larry Apr 18, 2022
    If it was sold as a working board you can return it at the sellers expense. If you decide you want the challenge of fixing it and your missing the standby voltage look at the regulator MOSFET and it's associated circuitry, no standby is an easy fix even without a schematic as all hot sections on tv power boards have the same circuitry, you can use a schematic from any old set to get the layout
Connected to cable box sound no picture reboot left tv on 3 hrs. fine. turned off. 2 hours later turned on now no pic just sound. When the tv is cold no pic. when warm pic. ???
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc
2answers
A light horizontal line has appeared on my Samsung UN55C6500 TV. Is there a fix for this?
Horizontal lines on LCD TV,
not usually repairable
plasma may have a corroded or dirty connection on ribbon cable left side of TV looking from the rear
1helpful
2answers
Samsung led tv ua40F6400 power board
If you wish to buy a new power board, contact the authorized service centre for Samsung.
3answers
I have a panasonic TC-P42C1 blinks 10 times no picture no sound What is common to go on this model (which board)?
Check the tv power supply board.That the board where the tv power A/c plug into it.Check the tv power supply board carefully for dying components parts that are called capacitors parts.Bad or dying capacitors parts on the tv power supply board are alway causes this problems to the tv.Bad or dying capacitors parts are very easily to spots,all these capacitors parts are alway bulges up onto it tops.Never have plats round tops as they suppose too.U have all the tools and know basic electronic also can do basic soldering work,u should changes all these dying capacitors parts in the tv power supply board with no problems at all.If u check all over the tv power supply board and it have no dying and leaking capacitors parts to the tv power supply board all.Then the tv Y-Sustain main logic Tuner board it is the causes and the problems.The tv Y-Sustain main logic Tuner signal board that is the board that take in the tv imcomming tv broadcasting signal cable plug into it.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board and or the tv Y-Sustain main logic Tuner signal board for the replacement.
2answers
My LG 26LH20 turns itseld off after about 2-3 seconds. TV is a little over 1 yr old. I t happened about 2 months ago and I thought it was the cable. had cable serviced, not the problem. now it's...
Tv turn itself off after 2-3 seconds the tv still audio voices?Yes,than the tv long board that call the LCD inverter board it is dead.Require change the tv long LCD inverter board,this board help the LCD screen panel to have a backlight to produced a picture or 2-3 seconds tv power died completely no power to tv all?Yes,than this problems the tv power supply board it is dying.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board or the tv power supply board for the replacement.
Whats the output voltage for an logic board
Make and model of the TV will help me looking for free service manual. Most LCD TV power supply will feed the main board with 5vdc and then it gets step down to 3.3, 2.2, or 1.8v for the logic circuits, the power supply also feeds 12~16vdc for the sound output circuits.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Audio on blank screen !!!! wat to do !!! vistron tv
IF the backlights are on but you just get dim glowing on the screen when look at the screen in darkened room then the T-CON board is bad or it is not getting the 12vdc from the main logic board. Need to use logical troubleshooting before buying the wrong parts, but if otherwise then,
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
often that *needs* to be done in a service center as there are some adjustments to be made after replacement; don't know about this particular TV model,
2answers
Power supply not work samsung plasma tvmodel
www.scribd.com/doc/.../LG-TV-Plasma-Training-Manual
www.scribd.com/.../LG-Training-Manual-TV-Plasma-60-INCH-PDP
http://www.schematicsforfree.com/archive/file/Sony/Video/Sony%20Plasma%20Training-1.pdf
please use these service and training manual, to troubleshoot and service.
We have a Toshiba 52 inch TV, model # TP50G50, manafactor date on it is July 1997. The picture & the sound went out all at once, do you know if it's a fuse or something more serious? It's hard to haul...
It is a power supply fault. The power supply is a switched mode power supply and supplies 5 volts for the difital logic and high voltages for the high voltage parts of the tv relating to the screen display components. When the high voltage part of the circuit breaks or goes short circuit then the power supply shuts that part down leaving the low voltage rail of 5 volts..hence the standby still working. So... you need to be looking at the power supply board where the mains goes in but be aware of the mains voltages in this area if you arent experienced in electrics. The board will still hold 240v if the power supply has an open circuit load
1helpful
2answers
50HP95 Toshiba Plasma TV No power but blinking power light
I had the same problem with my 50HP95 Toshiba Plasma TV. It would not turn on. I read online that if you unplug a connection on my TV and it turns on, it is a bad Seine board. I could not find this Seine board anywhere online. It was either out of stock or no longer available. The TV is just 5 year old. Why would they discontinue parts for it? Then I saw a video on You Tube where someone unplugged a connection in the back of his TV to fix problem. I decided to try it. I took the back off, unplugged a connection numbered PJ63A and the TV works again. So far so good. I downloaded the Service manual for this TV to find where PJ63A was.
I also called Toshiba Tech Dept. to find out if there was a chance I can cause further damage to my TV. They had no idea.
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
