Washing Machines Logo
Question about Electrolux Washing Machines
Electrolux model ADTRTER6 have showing error 72..can u please help?
Drying tunnel
Posted by Ajil Abraham on
Electrolux EWW1141AESA Washer-Dryer isn't drying
If it is new, contact the seller under warranty. This model is only available in Saudi Arabia, we are in North America. According to the specs, it is a condenser dryer with no vent to outside. These do take longer to dry, but they should dry eventually.
https://www.electrolux.sa/en-sa/appliances/washer-dryers/eww1141aesa/#specifications
What's the meaning of error code E3 on my Electrolux model EWT604? The washing machine just beeps 3 times and showing an E3 error code on the LCD. Please, I need help. Thanks.
Abnormal condition of spin-dry
• The safety switch works 3 times continuously.
The number window LED display abnormal code: "E3" and begin blinking on and off at the same time and the electric buzzer sounds to indicate a problem.
Dado
I have an Electrolux gas dryer, front loader and while drying bed sheets it gave the error F1
unplug wait a minute plug back in see if it resets.
most electrolux have E error codes followed by 2 numbers.
Press and hold the "Temperature" and "Dryness" buttons simultaneously for 6 seconds to do a factory reset.
hope this helps.
1helpful
2answers
I have Samsung gas dryer model DV410. no heat, replaced two thermal fuse and hi low limit. Now it only works with timed cycle mode. the rest mode, it runs only for least the 5 minutes and shut off.
timed cycle mean dryer not on sensor dry mode. check wire connection on moisture sensor bars (i think you forget to put 2 wire connector put together). when you use other cycle dryer use moisture sensor to dry cloths so sensor not working dryer will stop in 5 minutes or so because dryer think there are no wet cloths to dry. hope this help you.
Electrolux Dryer, model no T-31200 has error E-05
Sounds like your breather is blocked look at the bottom of the unit for a filters remove and clean
Big
Electrolux washing machine showing error 33(no interlock). what do I do?thanks
Hey Desmond, thank you for your inquiry!
From my understanding your Electrolux washer is displaying an error code of 33. I am showing that is an invalid error code. This could be a miscommunication within your control panel. I would suggest performing a reset on your washer and you can do that by disconnecting power from it for at least ten minutes. If the reset does not help correct the issue and the error code comes back please comment back. Also, let us know your model number. You can locate the model number of the door frame of your washer. Once I have that information I would be able to assist you further. -Matt
1helpful
2answers
ELECTROLUX WAVE TOUCH GIVING ERROR CODE 4
Hello JOHN, thanks for your post!
From the information you have provided your Electrolux dishwasher is displaying error code 4. "E4" stands for drying damper which means it could be a potential problem with your damper or the main control. I would recommend performing a reset and that could clear any false error codes. To reset your dishwasher flip the household circuit breaker off for roughly ten minutes. If that does not help correct the issue I would recommend having a professional technician out to properly repair it. Good luck. -Matt
I have an error 04 showing on my dishwasher, and the cycle will not run. Please help!
dryer damper problem. there is another post that will help from electrolux personnel.
Thank you in advance for allowing Electrolux to assist you in
this matter.
I apologize for the inconvenience and concerns this dishwasher unit has been causing you. Unfortunately the error "E04" code does indicate an issue with the drying damper. Now this is something that a technician would have to assess because wiring is needed to be checked.
Check wiring between Main Control Board and upper fan. If correct, replace upper fan.
If your unit is brand new it is covered under warranty and you can choose to contact your dealer for a repair technician, or visit www.electroluxappliances.com/servicelocator to find a listing in your area.
Kindest Regards,
Chris Polk
Online Outreach Representative
Electrolux Major Appliances
Er 01
Leak Detector - When water is detected under
the tub.
Er 02
Thermistor - When thermistor/turbidity module
fails
Er 03
Wash Pump - Wash pump not operating
Er 04
Drying Damper - Drying damper not operating
Er 05
Upper Fan - When in the dry cycle, the control
board does not receive proper speed feedback
from the upper fan
Er 06
Lower Fan - When in the dry cycle, the control
from the lower fan
Er 07
Drain Valve - When in the drain mode, the control
board does not receive proper position feedback
from the drain valve
Er 08
Tactile or touch switch - Control board has
verified a switch on the user interface is bad or
shorted
Er 09
Communications - Communication failure between
main user board and power supply
Er 10
Mains Relay - Failure in the mains power relay
Er 11
Drain Valve - Time out before finding a state for
the drain valve
Er 12
Drain Valve - The drain valve is running when it
should be off
Er 13
System wide - Lost control of the State Machine
6helpful
Dishlex dx 403 does not dry dishes - fan dry on red led
Ther have been a lot of complaints about the drying performance of these machines. One solution suggested by Electrolux is to use the "anti bacterial" wash mode, as this is a higher temperature wash, therefore dishes dry better. If you are using Eco wash or Quick wash, drying performance is not very good- Electrolux recommend leaving door ajar at end of cycle to improve drying. Also, ensure your Rinse Aid compartment is topped up, as Rinse Aid greatly improves drying performance.
-Please note: these dishwashers will not dry plastics and other items that do not hold the heat very well!!
-Also, you should be able to hear the drying fan running at the end of cycle- if not, then you may have faulty fan (uncommon), or control board (more common).
Good luck!!
Open Questions:
Top Electrolux Washing Machines Experts
David Shaub
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
