Plumbing Logo
Question about Delta Plumbing
My delta touch faucet only has small stream what do I do
Aerator is clear. Already checked. Replaced batteries
Posted by Agnes Bohanan on
john h
    Top Expert:
  • Delta Master
  • 28,887 Answers
No info generic answer poor water pressure---valve /water line clogging / failing
Posted on Apr 14, 2022
3answers
Delta kitchen faucet called the shiloh with low water pressure
There is normally a filter at the end of the faucet outlet. They usually unscrew. its usually a fine mesh screen with a plastic backing mount.
My delta touch faucet only let a trickle of water run I have replaced the batteries, it is a model 19922 sssd dst
Have you unscrewed and checked the aerator? It could have trapped debris built up inside thus preventing efficient flow.
Nov 02, 2014 • Plumbing
Leaking faucet
Remove the handles. See if the chrome slip nuts holding the stems in are corroded. If they are, the cartridges may not be fully seated or the o -rings that seal around the cartridges may need to be replaced. If either of these is the case you can tell for sure by turning the stems to the on position with the handles removed and looking for water seeping around the cartridge. If none of the above is the cause then check to see if the aerator (screen on the spout) is loose or corroded sending a light spray back towards the faucet body that looks like a leak. If this is the case remove and clean the aerator, then reinstall it making sure not to cross thread it. If none of the above, replace the faucet. Be sure to call Delta first before replacing because they have a lifetime warranty and you just might get your faucet for free!
Delta 2467 water flow has gotten very slow. Do I have to remove the whole faucet from under the sink, or is there a way to clean it out from up above. Already replaced the faucet cartridges and the...
Hi, i would suggest to check the faucet and make some adjustment for proper water flow and if you already replaced the faucet then this problem should not occur , i have had same problem and i had called A-General for this and they fixed easily all issues ,please take some help http://www.a-general.com
How do you remove the spout cap (RP34090) from a 2 handle delta 2402 kitchen faucet? The spout cap is stuck.
If you are talking about the aerator at the end of the spout,take a pair of pliers and a rag put the rag on the aerator and turn counter clockwise(take care to make sure rag is covering all the area and that should help you get it off.If you plan on replaceing aerator which is about $6 just take the pliers and take it off.
We have a screen inside of the nozzle that we can not get to. We've tried with a tooth pick etc. When there is a water outtage and they turn back on the water it sends a rush of junk and we have to be...
The screen is held in place by a threaded piece on the end of the faucet - collectively the screen along with the threaded piece is called the aerator. The aerator must be unscrewed to remove and clean the screen. A pair of pliers or a pipe wrench may be necessary if the aerator is tightened beyond hand tight or if corroded with mineral deposits.
Have you been able to remove the aerator?
Regards,
DIYpro
2helpful
Hello, I replaced the seats and springs in my faucet Delta Leland 2578 and now my water pressure is low. So I thought it was the stem unit assembly because it had a lot of deposits on it so I replaced...
it would only be aerator if hot and cold were low..what happened is when u shut angle stop off on hot water to replace assmbly..the washer on angle stop separated and is blocking the supply
2answers
The pressure in my Delta faucet is suddenly low. The pressure throughout the rest of the house is fine. What is wrong? I replaced several pieces of the faucet but nothing worked.
Take the hoses off on the bottom of the faucet and blow air back through the faucet. Dirt can plug up the small openings right where the water enters the faucet. By the way I hope you checked the areator on the end of the spout, Dirt can plug that up also.
Top Delta Plumbing Experts
David Shaub
john h
Mike
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
