If the auto shred function on the MD 1250 persists without stopping, potential causes include sensor misalignment, paper jams, software glitches, manual control issues, or power supply irregularities. Refer to the user manual for troubleshooting or contact the manufacturer for assistance in resolving the iss
It's a tedious process to clean it out. Most auto switch shredders use either a tiny little lever or an optical sensor in the paper feed slot. Usually removing the shred head, picking all the paper out and blasting all the dust out with air will clean it up. Then run a few sheets of paper with shredder lubricant (basically clean mineral oil) to oil the blades and it should be good to go again. Just be careful cleaning that cutting head. I've donated many drops of blood to office equipment over the years.
If place too many pages in the shredder the motor will be overworked and it will overheat and shut down until it has cooled down. Try shredding fewer pages at a time.
I got mine to work by running it on reverse for a moment then sliding it to auto. It stopped. Then I did it again. This time auto ran just for a second then stopped. I did it a third time but I had a sheet of paper ready in the feeder. Ran on reverse. Slid it to auto and it took the paper and shred it. I did it a fourth time. Reverse slide auto and feed shred the paper. Fifth time Auto shred the paper without reverse. :)
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
If you have a strip cut machine it may be a problem with the gears. if it is not a strip cut it may be overheating due to not being oiled. First check with your manual to make sure you are not exceeding your duty cycle some machines only have a 2min on and 10 min off cycle,
