Question about Maytag Ensignia MAV4758AWW Top Load Washer
Squeeks when washing - Maytag Ensignia MAV4758AWW Top Load Washer
Posted by bruce_gra978 on
blueextc3221
  • 15,935 Answers
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%%%
Posted on Oct 01, 2010
What does it mean when I hearslight squeek when the tub turns, sounds like it is coming from the rear of the machine
bearings? or sometimes litle things can get stuck in between tub and housing and cause funny noises
Sep 08, 2014 | Maytag Neptune Washing Machines
My hotpoint washing machine WF620, squeeks when it is washing and spinning
On most hotpoint wash machines you cant replace or grease the bearing you have to replace the whole drum which cost around 100 pounds from hotpoint and a couple of hours labour its a common problem on hotpoint machines.
hope this helps.
puggy
Jan 07, 2014 | Hotpoint Aquarius WD63 Front Load...
Maytag front loader HE washer.
cheak your tube if there is a nail or an object is stuck in one of the holes
Jan 24, 2010 | Maytag MAH6700A Neptune High Efficiency...
Kenmore washing machine makes a squeeking noise
Sounds like you have something between the tubs. If it only does this in the spin cycle, I would look for something between the tubs
Please rate solution if helpful
Aug 24, 2009 | Kenmore Washing Machines
WASHER WILL NOT DRAIN AND MAKES A SQUEEKING SOUND
Sounds to me as if you may have some kind of debris stuck in your drain pump. Try removing the pump and clearing it out and I'll bet your problem goes away.
Jul 30, 2009 | Frigidaire Washing Machines
Washing maching squeeks while in spin cycles
Try this... if you can, spray some wd-40 all over the motor and transmission shafts... sometimes, using a powder detergent can clog it up OR just the normal wear and tear if you using a liquid... it's always a good idea to run thru a cycle of bleach on your hottest setting. it break up that debris and is considered good upkeep.
Feb 22, 2009 | Washing Machines
Maytag model# sav365zaww squeeks
check your pump the bearings in your pump
could be going out this will cause the water not to be pumped out properly and will also cause a squeek
Dec 29, 2008 | Maytag SAV365Z Top Load Washer
Squeeking during wash cycle
Hi jbramwilliam
I'm Harvey the Master Plumber.
Sometimes this is caused because something is now rubbing. Make sure:
The screws are secure to the counter,
The d/w is perfectly level,
The legs are all tight to the floor,
If the back legs are wheels then shim with wood blocks.
If it still squeeks then you have a warranty problem.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 12, 2008 | GE PDW8200NWW / PDW8200NBB Dishwasher
In the rinse cycle the washer is making a squeeking noise
check whether there is something inside the washing drum ..
by mistake some thing might have fallen inside..
else the bearings would have worn out making the squeeking noise..
thankyou..
Mar 13, 2008 | Frigidaire GLWS1233A Top Load Washer
Kenmore Elite model: 22932
Washing machine works fine UNTIL spin cycle. Loud engaging sound and then it makes a squeek, squeek sound...not really a squeek, but if you were to listen to it, eee, eee, eee, eee, eee and loud.
Dec 10, 2007 | Washing Machines
Maytag Ensignia MAV4758AWW Top Load Washer Logo
91 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
jdthefixer
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
