We installed a Frigidaire Gallery FGGH3047VF and used an LP/Propane conversion kit. All burners and broiler are burning great. The oven, however has large flames that shoot orange out the cover and up the inside walls. Is there another orifice we are missing?
Make sure you changed regulator and all orfices then make sure gas pressure correct propane burns hotter than natural gas
Testimonial: "Thanks, David. We turned around the valve on the regulator and all the burner orifices. There wasn’t one for the oven - which we found odd some the one there is quite large. We turned the valve as directed (both ways to be sure) but never changed enough to lower the flame."
Yes sounds like you missed the oven burners at the bottom of unit
That seemed logical to us as well but unfortunately the only orifice that is referenced is a larger one that does not have a replacement.
Im having same issues, with same model. Have you fixed the issue ?
Did you figure this out? We just got ours. I think you have to take the back panel off and then remove the tube going to the oven to adjust the spud. Is that correct?
Hello Carlos - Does you range have an LP conversion kit installed? If so, I would recommend verifying that unit is set to appropriate fuel and fuel conversion kit is finished. Also trying adjusting the pressure regulator and/or air shutter.
