Car Audio & Video Logo
Question about Alpine Car Audio & Video
My Alpine CDE-W235BT bluetooth has stopped working after a failed update. How do I fix it? I tried to update Alpine w235bt. The update froze and I waited for some time but then I stopped the update by switching off the car. I did not think anything will happen but now everything works except the bluetooth. The bluetooth is as if it is disabled. If I go to the bluetooth menu I can scroll through the menu but not select anything.
Posted by Andrei Ioan on
I have an Alpine CDE-SXM145BT car stereo. that will not play Bluetooth devices.
Have you had the battery removed at any time before this happened or been jump started ?
1helpful
Why I have no sound on Alpine CDE-111R. After six years appeared an option which it never appeared before, "BT AUDIO".After that is no sound anymore
Seems that you activated Bluetooth audio for playing music from a Bluetooth device. If you google alpine cde111 manual you will get a link to the owners manual which gives step by step instructions on how to disable Bluetooth audio
How to set up to run
If you don't have the owner's manual, get to the Alpine website to ask for assistant. Often you can download instructions or manuals free.
https://supportalpineusa.custhelp.com/app/home
Does not power on
Check the fuse in the fuse box of your car and if that doesn't help there is a fuse on the back of the alpine unit. And if this doesn't fix the problem then most likely you have a bad unit.
2answers
Sounds to me like the firmware is damaged, try flashing it with another firmware, or maybe updating it with the same update but successfully if possible.
Alpine cde-126bt bluetooth connection issues, only connects with 1 phone, second device fails at connecting when using pin.(0000). software ver is 3.80
Hi, same problem (v3.80), but finally conected. I would say that is related with bluetooth name length of the phone.
Try setting the phon's name to something smaller.
Jordi.
Conected with an android device, Motorola MB200 (DEXT)
Alpine searching for ipod...
I was told if you updated your ipod  or have a newer version it wont work im having the same issues trying to find the old versions of itunes to see if it helps will post if it does
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
