Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Washer runs and spins great but leaks on the rinse cycle. It’s a top load GWL10US model. The drain hose was wet at the elbow where it meets the pump hose after we ran a wash but dry at the top where it enters the unit.
Question edited to correct name of maker, (Fisher PayPal :>)
Question moved to one of their categories.
No clue to whether a top loader or a front loader, which is why we ask for full 'make model (what it is)'.
If it is only in the rinse cycle, and if it is a front loader it is likely to be spray of a crack in the box that is the detergent drawer and fabric softener mixer. The only way to find out is to remove the top after a wash and look for where the water came from.
Some other ideas here
https://www.google.com/search?q=Fisher+and+Paykel+washer+is+leaking+water+from+bottom+back+right+side
Posted on Mar 27, 2022
Testimonial: "Oh sorry, it is top load GWL10US. We looked under the washer and saw water on the drain hose, it was dry at the top of the hose where it enters the unit,, didn’t see any cracks or holes in the hose tho"
On a top load it is likely to be from the drum to the pump, or the drain hose itself. There is also a diverter valve involved in water management. Cracks don't need to be very big as the flex and open during running.
http://www.genuineapplianceparts.net/cat...
Here is the Service Manual, just because I came across it. Deals mainly with the electronics.
https://applianceassistant.com/ServiceMa...
Thank you Andrew!
Would there be any harm if I duck taped the elbow that was wet and then ran a wash to see if the drain hose stayed dry?
You can try it. It the pipe is dry it should hold.
