I have an Electrolux Icon wall oven. It will be asleep and no one has used it for days. Just clock on display. All of a sudden with no one anywhere in the vicinity, the oven wakes up with a beep, stays lit up for a couple minutes then goes back to sleep. This will repeat at a random interval. Shutting the breaker and leaving it off for several days then powering again results in no problem for even a number of days, I have seen almost a month, then randomly starts this random wake up and beep again. If I just quickly turn it off and then back on after just a short duration, it may start beeping again in a shorter time.. Any idea what's up with this thing? Is the control panel defective or something else ?
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
Hi
This means a
loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the
door appears to be closing fine then it is the control board that is bad and
should be replaced. Hope this helps...please post back for further assistance.
Daniel
Seems
like you found out the hard way what I wrote about in this
tip...
Check it out it also contains some thing to try on how
to unlock that oven..
Self
Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I
never would have used the self cleaning option. Thanks for the info!!
" - amymrocks
