Washing Machines Logo
Question about Electrolux Washing Machines
Electrolux washer model EWFLW65F error code e9f - Parts Replaced
Washer displaying error e9f. You can hear what I believe is the pump running. It is doing nothing else. Test 10 from service manual completed. Wiring checked good. Changed main control board and machine will not power up... all displays/buttons are dark. Plugged old board back in and machine powers up. Error of course is displayed. Changed board out again with a different board both same part number as original and does not power up. Changed the user interface board out and again machine will not power up. Reinstall old parts and machine powers up. Even tried doing a reset by holding play/pause button and plugging in. Still will not power up. Can't get unit into diagnostic mode either. All parts replaced were either the same part number as replaced components or part number directed by parts sellers. It seems as though there is a firmware compatibility issue. Electrolux tech support instructs calling service tech. Would they have ability to change firmware or would same parts just be instructed to be replaced. If anyone has any similar experience info would be greatly appreciated. Next step of course is to replace machine. Thanks in advance for assistance.
Posted by MJ Hodge on
ADMIN Andrew
    Top Expert:
  • Electrolux Master
  • 52,944 Answers
Sounds like you did great job of following the service manual and advice for parts suppliers, but often, it is service tech knowledge that is useful. For instance they will look at a board and say "yes, this board fits most of them, but not yours", or they say "these boards are made on Taiwan for 5 bucks each and 8/10 don't work, I keep 20 in the van". also these days, techs carry a laptop computer and connect to a Service Port, like the OBD2 port on a car. The machine tells them the issue.
Your choice, Service Call or Shiny New Machine. You can't do any more than you have done.
you have obviously seen this, but did you check the connection to the Inverter board on the motor and the soldered joints behind the connection? Different model, same code.
E9F: Communication Error Between Main Board And Inverter ...
https://www.manualslib.com > ... > Service manual
Electrolux EWM25 series Manual Online: E9F: Communication Error Between Main Board And Inverter Board. E9F Checks to perform: Measure the continuity between ...
Posted on Mar 24, 2022
Testimonial: "Thank you for the time Andrew. Yes I did see that issue. I completed it and forgot to mention I also threw an inverter board at this too...albeit used. Regardless, yes I know a service tech would have training that I don't. That is reason for throwing issue out there is to see if anyone knew if a tech would have additional tooling or would say a component needed replaced. It seems I've changed all. As you can see I'm pretty deep into this at this point. I didn't want to throw more at it if they didn't have additional resources. Probably already should have pulled plug and got the shiny new machine. Just hate to leave one behind. Again thank you for your input/time."
  • 1 more comment
  • ADMIN Andrew
    ADMIN Andrew Mar 24, 2022
    Yes I can see that you have invested a lot of time and parts. One problem with used parts is that they are DOA on arrival. My advice, get the service guy in, make him coffee, chat and watch. You will get a working machine, and knowledge. You already have spare parts for the future. It looks to be a nice machine.
  • MJ Hodge
    MJ Hodge Mar 24, 2022
    Thank you sir. Yes, I have a decision to make. The inverter board was the only one that was purchased used. Others have been expensive new.
  • ADMIN Andrew
    I would love to know what you decide if you don't mind. It is not an easy decision. We see the same thing with television repairs. Posters change every board (normally 3 at $50) and still don't have an operating set.
My electrolux type EWF10842, on display find error EHO, what mean this error,and how to resset, thanks
The EHO (or EH0) error indicates a problem with the incoming power or an electrical problem inside the washer. Unplug the washer for a while to reset the error code. Next check your wiring and make sure that the outlet doesn't have a fault. If you live in an area with brown-outs or wires that touched during a storm, wait until the electricity is repaired. Then check if the power supply to the washer was damaged by the surge or changing power levels.
If these aren't responsible for the problem, you'll need to check the wiring for shielding damage, the wire harnesses and the rest of the washer. There is a parts diagram here: http://docplayer.net/60693214-Spare-parts-list-household-washing-machines-pnc-elc-brand-model-market-electrolux-ewf10842-th-washing-machines-front-loaded.html .
I hope this helps.
1helpful
How to fix a E9F error code of EWF1282 FRONT LOADER ELECTROLUX WASING MACHINE
E9F - Communication error between main PCB and Inverter board.
Could be:
  • Faulty wiring between main PCB and Inverter;
  • Inverter PCB faulty;
  • Main PCB faulty
Dado
Electrolux washing machine showing error 33(no interlock). what do I do?thanks
Hey Desmond, thank you for your inquiry!
From my understanding your Electrolux washer is displaying an error code of 33. I am showing that is an invalid error code. This could be a miscommunication within your control panel. I would suggest performing a reset on your washer and you can do that by disconnecting power from it for at least ten minutes. If the reset does not help correct the issue and the error code comes back please comment back. Also, let us know your model number. You can locate the model number of the door frame of your washer. Once I have that information I would be able to assist you further. -Matt
1helpful
2answers
My Electrolux washing machine is showing error codes MB Alarm E33, and UI Alarm E00. It has stopped working altogether. Door wont open and clothes are stuck in ther. I have run a diagnostic test and it...
I appreciate your post, Anonymous!
From what you have described your Electrolux washer is displaying an error code of MB, E33, and UI Alarm E00. I have been unable to locate those error codes. May I have your model number, please? With that information I will be able to assist you further. -Matt
How to fix error code 0.00
Hello friend, thanks for your post!
Based off the information you provided your Electrolux washer is displaying "0.00". Typically any error code that is labeled "00" means no error code stored, which means it's a false error code. I would recommend performing a reset on your washer due erase any false error codes. You can do that by disconnecting the power from your appliance, by either unplugging it or flipping the household circuit breaker, for ten minutes.
If this step does not help resolve the problem please provide me with the new error code or if your display continues to show "0.00" I would suggest seeking assistance from a professional to come out and properly diagnosis your washer. I hope this information is helpful. -Matt
How to fix the error code E40 on Electrolux EWF1073 Front Load Washer?
I don't have an electrolux, but I have an LG front loader. Mine was giving a simular error code, and I found the drain hose filter was clogged. Bee running fine since
Error e9f
Hello - Typically error code E9F indicates a communication problem. A certified technician will need to check the wiring between the main control board and the speed control board. Depending on the diagnostic either the wiring, main control board or speed control board would need to be replaced. Contact a professional to move forward accurately.
How do i reset an electrolux 1080
E20 is an error code for a drain pump issue. The error will reset itself if the issue has been resolved. If it or another code continued to appear, then the unit has not been accurately fixed.
Affinity front loader ATF7000FGO E23 ERROR
E23 error code means the drain pump relay on the control board failed or wire off pump. You already replaced control board so check the wire at the pump and make sure it's secure.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134879700.pdf
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
20helpful
6answers
Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
Top Electrolux Washing Machines Experts
David Shaub
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
