Iv got a Vision Rascal mobility scooter ...i use it every day ...but now when i try to turn on my head lights ..no matter how many times i press the button no lights work
Iv got a Vision Rascal mobility scooter ...i use it every day ..i try to turn on my head lights ..no matter how many times i press the button no head lights work
Hi marilyn, Sadly no mobility scooter manual will give you such information, i willing to help , what do you want to know ? faulty lights , thinking of fitting a new controller ?
Hi, To get to the head light bulb you need to take the tiller head apart by removing the screws that go up from the bottom. The top will lift off but be careful not to pull any wires off. This will give you access to the lamp at the front. Make sure you replace the bulb with the same type and voltage.
A blown charging circuit fuse? The fuse may be under a floor hatch and mat and not feature in the manual - that turned out to be the case with a Pride Mobility scooter.
I would contact your Rascal dealer for a replacement key switch.
You could try spraying some switch cleaner in the key slot and work the key to see if it is just dirt but I would imagine it is worn out.
Good day to you.These series or blinks or bleeps are codes to determine the fault.& the trouble you will find is Shoprider etc will not give out info to the public.Contacting a Scooter repair shop is a good idea,reason being.They can order your part if needed.You can also download:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772 as a PDF File,if you do anything yourself.Remember a repair shop will be hesitant to even look at it & I suggest you take a photo of every step if fixing yourself with your mobile.Have a nice day,hope I was of help.Colin
