Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Had similar problem (ie. 2 green & red flashed followed by 5 red flashes - Fan blowing but not cooling ... I also noted that the outside unit fan wasn't going). Tried restarting several time after waiting only a minute or two after turning the mains power off but with no change. So turned the unit off at the mains power and then fired it up about 2hrs later and it was all working fine.
Power LED Blinking timing chart When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit. blinking
1 dg board, (stv 5v sense time out) 2 d board 3 d board 4 p board 5 d board 6 su sd sc boards 7 su sd sc boards 8 ss board 9 panel config 10 digi board- 11 pb board 12 h board 13 dg board
E5 means cartridges error - to fix press the
"stop\reset" button for 5-7 seconds and then release it.
You can also try this:
1) With the printer power turned off but connected to a power source, while pressing the Resume/Cancel
button, press and hold the Power button. (DO NOT release the buttons.
The Power LED lights in green to indicate that a function is
selectable.)
2) While holding the Power button, release the
Resume/Cancel button. (DO NOT release the Power button.)
3) While
holding the Power button, press the Resume/Cancel button 2 times, and
then release both the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately,
Alarm in orange and Power in green, starting with Alarm LED.)
4)
When the Power LED lights in green, press the Resume/Cancel button the
specified number of time(s)according to the function listed in the table
below. (Each time the Resume/Cancel button is pressed, the Alarm and Power
LEDs light alternately, Alarm in orange and Power in green, starting
with Alarm LED.)
Service manual says 3 flashing red leds = eeprom error (main digital / video pcb).
Suggest you start by implementation of Fujitsu Service Bulletin PDP 0068-01 Main Digital pcb see:-ttp://www.eserviceinfo.com/download.php?fileid=43450
Thank you for contacting Fixya.
You need to check the blinking times of the Paer jam LED. Then check the followings:
1. If the lamp is on, then ADF Switch is malfunctioning. Disble or short the switch.
2. If the lamp is off, then it is Flatbed or ADF Inverter error. Lamp inverter circuit is to be replaced.
5. If the Lamp is still off, then Lamp is to be replaced.
6. If the issue still persists, then you may have to contact the authorized Avision Service personnel for further diagnosis and suggested repair or replacement.
Hope the above information is helpful.
Please revert if you have any doubt.
Regards,
TechSatya
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the
point that they need to be replaced. Operation of the set in a dirty
environment is not a good idea
