Anyone ever had issue connecting a Nextech wireless Bluetooth 4.1 Headset to a PC?
Hi everyone.
I have a headset that use to work correctly in the past. I did lose my Bluetooth connection from time to time but pairing it again use to revolve the issue.
This time though it did not work and what actually happened is that the pairing seems to work and even shows on the Bluetooth menu that the device is connected, but when I go to the "Playback Device" the device does not appear anymore. So I cannot even enable/disable it nor can I select "connect".
I have tried multiple things such as updating various drivers, (including Bluetooth) but still cannot manage to have any sound coming out from my headset or from the mic (it's a headset with a mic)
Any help would be welcome as I cannot use it anymore at this time.
Multipoint is a new development in Bluetooth technology that allows your headset to be connected to two Bluetooth devices at the same time. When a call
comes in, the Bluetooth headset knows which handset is ringing and will connect to
the phone automatically. Multipoint can benefit most Bluetooth Headset users.
1.From the main home screen of the iphone open "SETTINGS".
2.From the setting menu go to "GENERAL".
3.From General go to "BLUETOOTH".
4.In the Bluetooth menu you will see an on/off switch. Make sure you turn the switch to "ON".
5.From here you want to go to your bluetooth headset. Hold the on button for about 5-10 seconds until the light starts blinking. Once light is blinking go back to iphone.
6.In the Bluetooth menu (same as step 4) your iphone should have discovered your bluetooth headset. However if it is not paired yet. Open the headset menu.
7.In the headset menu you are required to enter the appropriate PIN number (which should be given inside your bluetooth headset instruction manual).
8.After you have entered the correct PIN number press connect.
9.From here your Bluetooth Headset should be connected and ready to use.
NOTE:Fully charge your bluetooth headset before syncing it to your iphone
For all Bluetooth headsets for computers you need the drivers most Bluetooth headsets don't install them for you, here is a website with the drivers and instructions. Just follow them and your headset will work. :) Hope that helps everyone! http://blog.komeil.com/2009/05/installing-bluetooth-headset-in-windows.html
Check to make sure that the bluetooth headset is compatible of connecting to the mobile device. If it is, then you will need to pair the devices using the Mobile Device. Make sure the Bluetooth Headset is switched on when the Mobile Device is trying to search for the Bluetooth Headset. It should work but if it doesn't, check the Manufacture's Website for any support.
Your friend should be able to use the headset if your friend's computer has Bluetooth feature. THe computer will send and receive the Bluetooth signals with one transmitter/receiver like your computer does and then connect to the wireless lan with a different transmitter/receiver system on a different frequency. Just make sure your friend's computer has Bluetooth feature turned on and then setup the headset by the "pairing" process.
follow the steps below: • Setting the headset into pairing mode 1) Ensure the headset is fully charged 2) The headset must be switch off 3) Press and hold the on button for +- 8 seconds until the light flashes red-blue 4) The headset is now in pairing mode • Searching for the headset on the phone 1) Go to “settings” or “connections” 2) Select Bluetooth, then options 3) Select Devices and click add 4) The phone should search for any available Bluetooth devices and display what was found 5) Select the Motorola device and click add 6) You will be required to enter in a pass code which is standard ‘0000’ 7) If successful then the headset will start flashing BLUE every few seconds. • The headset is now paired with the phone
If you have lost the pairing on your Blackberry with the headset follow these simple steps below:
• Searching for the headset on the Blackberry
4) The Blackberry should search for any available Bluetooth devices and display what was found
5) Select the Samsung device and click add
6) You will be required to enter in a pass code which is standard ‘0000’. If not try '1234'.
Open up the Sounds and Audio Devices control panel, hit the 'audio' tab and make sure that the default playback device is not the bluetooth phones, but rather you sound card.
