Question about Kenmore Microwave Ovens
I've already replaced the Megnetron high voltage capacitor and transformer as well as the high temp fuse. Yet every-time I plug it in hit start it makes a big vibration noise then shuts off and the fuse is blown. When I originally opened it because no power the Megnetron and transformer had burned cables so all replaced with new parts.
It is 'Magnetron'.
You shouldn't be in there Kate, there is heart stopping 120,000 volts, a poisonous heavy metal core in the magnetron and radiation that can blind you in 6 seconds. Qualified service personnel only on microwave ovens. Depending on age it is probably beyond ecomomic repair. If you have had it longer than 6 years, it is. It sounds like one of your new parts was the wrong part. If you bought them off eBay, they will be out of failed machines that have been scrapped, cleaned and resold. If you have some attraction to this oven, take it in for service. The technicians have the experience and the test equipment.
Posted on Mar 22, 2022
It sounds like the magnetron may have
either failed or is not being supplied with the extremely high
voltage required to run it.
Make sure the !!!!capacitor is
discharged!!!!! before attempting any sort of repair.
Check
the door interlock switches first then the high voltage diode with
either an AVO model 8 on high resistance range for short circuit, the
capacitor can fail and go short circuit, the feed fuse on the primary
of the high voltage transformer and then finally, the magnetron is
best checked by substitution.
Hope that helps.
Check
Hope that helps.
Some models may have a separate high voltage fuse. If this is blown, there will be no heating but no other symptoms. However, high voltage fuses are somewhat rare on domestic ovens.
A number of failures can result in the fuse NOT blowing but still no heat:
Depending on design, a number of other component failures could result in no heat as well including a defective relay or triac, interlock switch(s), and controller.
If you are interested in doing it yourself the following link will help : Microwave Repair Manual
(**All the above references to tests are found here)
