Televison & Video Logo
Question about Hitachi Televison & Video
My hitachi p50v702 says pip function not available
At first I had Dish network joey connected to HDMI 1 and DVD player connected to HDMI 2. I read on some website saying PIP will not work with both connected with HDMI. I reconnected the DVD to imput 3 and still having same peoblem.
Posted by Marty Owen on
HOW DO I PLAY A DVD USING Hitachi Flat Panel Television 32HDL51 (ITS CONNECTED THROUGH HDMI CABLE)
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
CONNECTING A COMPONENT SOURCE WITH HDMI or DVI CAPABILITY TO INPUT 1 or INPUT 2
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
http://tv.manualsonline.com/manuals/mfg/hitachi/lcd_television_lcd_display_monitor_32hdl51.html?p=18
How to work the hdmi
how do you set up the HDMI input on a hitachi tv model #51F59A ...
https://answers.yahoo.com/question/index?qid...
Jan 8, 2010 - i tried to hook up an HDMI devise but i cant set it on input HDMI it ... My TV has HDMI, Component and AV inputs, which one should i use for my ...
HDMI not working - Hitachi 50VS69A - AVS Forum ' Home Theater ...
www.avsforum.com/.../948284-hdmi-not-working-hitachi-50vs69a.html
Dec 1, 2007 - 7 posts - ‎2 authors
I have a Hitachi 50VS69A 50 RP LCD HDTV connected to a Dish Network receiver that the HDMI input is not working on. I have been using the ... Hitachi P50H401 - all HDMI ports are dead - HELP!
Oct 2, 2008
Hitachi 51/57/65F59A CRT RPTV Tweaks Thread
Jan 19, 2007
More results from www.avsforum.com
How do I hook up my Joey dish network to audio video modulator
Hi Tammie, my name is Kimberly and I forma part of the Social Media Department with DISH. I Apologize for the delayed response. I hope this answer helps you in the future or can help someone else that may have the same question. In order to hook up a Joey to Audio all you need to do is make sure you will be connecting the Joey's output into the Audio's Input. For example if you will be connecting the joey directly to the Tv, using an HDMI cable, the Joeys Output for HDMI has to simply connect into the Input for HDMI on the Tv itself. Feel free to reach me at: [email protected] with any questions or concerns.
2helpful
My Element TV is hooked up to the Dish Network. I have a dvd hooked up to the TV also. What do I have to do to watch the dvd on the tv
To watch a DVD your player needs to be connected to the TV using a scart or RCA connectors (red, yellow and white) depending on the type of connections available to you. The easiest way to connect the DVD player to a television is via Audio/Video connections that are usually supplied with it.
Next plug in your DVD player and power it up.
Next use your remote to select AV 1, 2 or 3 or HDMI - depending on the input you used at the back of your TV. Insert DVD and play! For example, if the DVD player is connected to the SCART socket labeled Av1, then you need to select Av1 with the remote.
The use of your DVD player is not dependant on the dish receiver - it works on a serarate input direct to the TV. Connecting your DVD player in this manner direct to your TV will not affect your cable or antenna connection to your television.
Thanks for using FixYa. Please remember to leave a vote for the solution.
Snow on tv cant get bk to pic
Hi nelle_king my name is MikeHouston of DISH Network. There are a couple things we can do to get thatpicture back. What you will need to do is make sure the TV is on channel 3 orthe right input, and if the picture is still snowy and we are on the correctchannel/input you will need to reset the receiver by unplugging it for 10seconds and plugging it back in. After you plug it back in it will power up byitself and you should see the DISH Network screen. I will send the steps tohelp with the setup. b> # Sequentially follow the below steps until problem is resolved or until instructed to skip to another step 1 Verify HDMI Connections Verify HDMI cables are connected from the DISH receiver HDMI Out to the HDMI In of the Revue, and the HDMI Out of the Revue to the HDMI In of the TV. 2 Reset Revue and DISH Receiver Unplug both the Revue and DISH receiver for 10 seconds and plug back in. It may take up to 5 minutes for the reset process to be completed. 3 Check Receiver-to-TV Configuration Check that the wiring between your DISH receiver and your TV is configured properly using http://www.dish.com/wiring. 4 Secure Receiver-to-TV Connections Check that the connections between your DISH receiver, your TV, and any component(s) (VCR, DVD Player, etc.) in between are secure. 5 Bypass Revue Bypass the Revue and directly connect the DISH receiver to the TV using an HDMI cable.
2answers
Xbox and dish network problem
if you have like a dvd player then try hooking the xbox up to it in the front where the video is for the 3 plugs then try to plug dish network in the back of the dvd where the ant in plug is at then take the cord from the dvd player and plug it in the back of the tv if this dont work let me know
2answers
PLEASE HELP ME CONNECT MY DVD PLAYER TO MY NEW PROSCAN 32LB30Q.
Use either another HDMI cable (available at your local electronics store) or a component video and left/right audio cable to connect the two pieces together. The connections on the back panel of both pieces should be color coded and clearly marked.
HDMI connection???
Hi Greg,
Again, if you have a high definition dish box with HDMI output,and a dvd player with HDMI output,please connect them both directly to your TV HDMI inputs.
When watching TV(dishnetwork box).remember to switch the HDMI video inputs.
Same as your DVD player,you need to switch it under your TV video input.
solutiondoct
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
