Used machine wheel and rim are not broke but are used.
Question edited for clarity.
Question moved from Cars and Trucks.
Put it together and run a bucket of balls through it. If it holds, you are fine. If not, spares are readily available.
https://www.google.com/search?q=jugs+pitching+machine+parts
Testimonial: "It does not hold"
You need to work out why then? You said it was detached, but not broken. In that case a fixing must be missing. You need to find your particular model and then check the parts diagram for missing parts.
The glue broke off the wheel from the rim so do I need to glue it back to the rim or something else
No parts are missing
You can try contact adhesive, or just replace the wheel complete..
