Cameras Logo
Question about Sigma Cameras
What adapter do I need for a Sigma AF 75-300 lens on a Canon Rebel XTi SLR?
Posted by Laura Weidman on
ADMIN Andrew
    Top Expert:
  • Sigma Master
  • 53,546 Answers
Question edited for clarity.
You get the Sigma lens for the camera in Canon fit.
https://www.google.com/search?q=sigma+lens+af+75-300+for+canon+rebel+xti
Can you use Sigma lenses on Canon cameras?
Since Sigma lenses are made to be fully compatible with Canon cameras, they are backwards-compatible. This means that you can use a Sigma lens on a Canon DSLR camera. Similarly, the Sigma cameras are backwards-compatible with Canon lenses. Macro adapter loses the AF feature.
https://www.google.com/search?q=sigma+lens+af+75-300+mount+adapter+ring+for+canon+rebel+xti
Posted on Mar 19, 2022
DS 126151 error
What kind of error? Err 99?
You mention DS 126151, that's the model number. This camera is mostly know as Canon EOS Rebel XTi? Also known as the EOS 400D or EOS Kiss Digital X.
If you are getting a Err 99 while shooting, try any other lens that will fit on your Canon. In most cases the aperture will become defect in these lenses. Not worth repairing if you ask me. One thing you could do, is shoot only at its maximum aperture. So that'll be F4.0 at 70mm and F5.6 at 300mm. That might work, but that might not be suitable in every situation.
8helpful
Does Sigma 70-300mm f/4-5.6 DG Macro Telephoto Zoom Lens fit canon eos rebel
Sigma makes their lenses with a variety of camera mounts. If you get the lens with a Canon mount then yes, it will fit any EOS Rebel camera body. A lens with a Pentax mount, for example, will not fit a Canon camera.
Is it possible to convert a sigma lens to fit a canon body or by using an m42 adapter?
Sigma makes their lenses with a variety of mounts. If the lens has a Canon or M42 mount then there is no problem. If it has a Minolta mount, for example, then replacing the lens will be easier and just as cheap as changing the mount. If it has Nikon mount, you can buy adapters to fit it to Canon or M42 bodies.
1helpful
Are older Sigma Quantaray lenses that I used with a 35 mm SLR Canon Rebel 2000EOS compatible with new DSLR Canon bodies?
Yes. Bear in mind that many Canon digital SLRs have a sensor smaller than a frame of 35mm film. This results in the image being cropped, narrowing the field of view and making the lens behave as if it was of a longer focal length.
1helpful
Will Sigma 75-300 f/4-5.6 DL work on my rebel XTi
If the lens has a Nikon mount (as you imply in the post), then no, it will not fit. If it has a Canon mount, then yes, it will work fine on your Canon Rebel.
Matching 2 brands
Simga makes lenses to fit several different makes of camera bodies including Canon and Nikon. I'm assuming your Sigma lens has a Nikon mount, if so there are some adapters, but they may not work like you want - not all functions may work properly thru the adapter. For best results you should return or sell the lens and get one with the Canon mount.
Sigma 70-300 AF lense
if the lens is the older type with a macro switch which has 2 screws holding it on to the lens it will not work.If it a super 70-300 you can put the camer on AV set iris to F22 if you have a stopdown button see if the lens stops down it ok if noe it will need a rechip or a new interuper
Sigma 70-300 mm lens wont focus
I was focusing to close to the subject & too much glare from a church window.
2answers
Canon rebel xt error messages
I have the same problem. So far I've contacted Sigma (I believe this is the company that manufacturers the Quantaray lens for Ritz) and they requested I send them a photo of the lens. I just googled sigma lens to find sigma support. I will update you all with any response I may get.
Top Sigma Cameras Experts
Steve
David Shaub
Are you a Sigma Camera Expert? Answer questions, earn points and help others
