M
Mater Johnson Posted on Mar 14, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why do I get error 202-0002 on my MF267DW Canon printer?
Don A
Level 3:
  • Canon Master 4,416 Answers
  • Posted on Mar 14, 2022
Don A
Canon Master
Level 3:
Answers
4416
Questions
5
Helped
1323938
Points
25670
ADMIN Andrew
Level 3:
Top Expert:
  • Canon Master 66,832 Answers
ADMIN Andrew
Canon Master
Level 3:
Top Expert:
Answers
66832
Questions
Helped
5058680
Points
379070
  • Code: E202 0002
  • Description:
  • Contact Image Sensor HP error, Failure in return
  • Remedy:
  • When the same error repeatedly occurs after several times of turning the power OFF/ON, execute the following remedies. 1. Check the connection of Flat Cable between Main Controller Board (J5) and Contact Image Sensor. 2. Replace the Flat Cable between Main Controller Board (J5) and Contact Image Sensor. 3. Replace the Contact Image Sensor. 4. Replace the Main Controller Board.
Canon MF267DW. Why do I get the code E202-0002 on my new MF267DW Canon printer?
If it is new, it needs to go back!
https://printcopy.info/?l=en&mod=erc&brand=Canon&model=imageCLASS%20MF249dw&code=E202%200002
  • Code: E202 0002
  • Description: Contact Image Sensor HP error, Failure in return
  • Remedy: When the same error repeatedly occurs after several times of turning the power OFF/ON, execute the following remedies. 1. Check the connection of Flat Cable between Main Controller Board (J5) and Contact Image Sensor. 2. Replace the Flat Cable between Main Controller Board (J5) and Contact Image Sensor. 3. Replace the Contact Image Sensor. 4. Replace the Main Controller Board.
2answers
How to Fix Canon Printer Error 5200 ?
Canon Printer Error 5200 may occur if the ink level in your printer is low or if you have a defective ink cartridge. Follow the steps to fix Canon printer 5200 Error code:
·Refill your cartridges/Ink tank
·Clean printer cartridge
·Factory reset printer
Find here the more canon printer error codes and their solutions.
2answers
3answers
How to Fix Canon Printer Error B200?
Canon Printer Error Code B200 here another common printer trouble you reasonably might have confronted one or several times when while using your printer. I liked to add this since I have read a lot of complaints about this error message. Canon Printer Error B200 usually links to a printhead problem and a failure message of support code B200 will flash on the LCD panel.
4 Easy steps to Fix Canon Printer Error B200:-
1. Switch off the printer. Remain until the cartridge carrier returns on the side.
2. Switch on the printer.
3. Remove the cartridges. Check the nozzles and clean them if there's any clogged or dried ink.
4. Reinstall the cartridges.
Canon Printer Error B200 has heard Canon printer users quite often. But, the good point is that there is a method that you can follow for managing and fixing this error. A reliable guide for troubleshooting can change the user's fix the Error Code B200.
To Fix Canon Printer Error B200, you want to join with Printer Error Support specialists. You can also follow the easy steps to Fix Canon Printer Error B200 are given below in this BLOG or Call us.
2answers
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
4answers
How do i fix error 5011?
Canon printer error code 5011 is also one of those errors that stop the printer from working. There are some methods by applying which you can easily resolve those errors.
Canon Printer Error 5011 is one of those errors which we can see difficulty by our canon printer. If the cartridge container becomes persistent and refuses to move to the center then this Canon Printer Error 5011 occurs in your canon printer.
Solutions that fix Canon Printer Error 5011:-
1. Switch off your printer and let it stay off for 3 minutes, then power it back on and test.
2. Lift the lid from the printer, including the scanner. With the lid open, turn the printer back on.
3. Then close the lid and see if that fixes the issue.
For full solution check this - Canon Printer Error 5011
2answers
3answers
Hi Guru.. just purchased a canon pixma MX347, removed all the packaging and started the printer and it gives me a 5011 error.. not sure what to do.. and Canon cusomer care seems to take their own sweet...
Canon Printer Error 5011 is one of the errors we can find with our Canon printer. If the holder of the cartridge becomes consistent and refuses to move to the middle, this 5011 error happens in your canon printer. If this error happens in a canon printer and you are going to print a paper, the error message showing the 5011 error will be shown on your screen or your canon printer.
Since this form of error also happens in various Canon printer models, this is a kind of malfunctioning Canon printer problem that stops users from retaining the scanning method. But immediately resolving the 5011 error code is important for a smooth printing experience with the Canon printer.
If your Canon Printer would have an error of 5011, that is mostly that the printer cartridge is jammed Or some Software error. The mistake may be corrected by Canon Support, according to Canon.
If the problem remains, check this blog or call Printer Error support services to stop more printer damage.
2answers
Canon error code 6500
The PCI bus error is detected by the ASIC. - Logic board problem
old marine
old marine
ZJ Limited
ZJ Limited
