Plumbing Logo
Question about Delta Plumbing
Delta cartridge for double-handled faucet will not seat properly.
The new Delta cartridge for my double-handled faucet will not seat properly and I cannot screw on the bonnet. I tried the old cartridge and, to my surprise, it also would not seat! I did not buy a new spring and top, but they seem in good condition and I can't imagine this is the problem.
Steve Pack
  • Delta Master
  • 6,355 Answers
There a little plastic tab on the cartridge that will line up with a notch in the valve body?...allowing it to go all the way in
Posted on Mar 06, 2022
Testimonial: "Thanks, I've matched the notches, but it still will not seat."
  • Steve Pack
    Steve Pack Mar 06, 2022
    did seat come loose.. I use a Phillips screwdriver and place seat on it and use it to hold seat while install it and then I press the seat fully down using my thumb or forefinger.
    https://www.youtube.com/watch?v=lXa78YsP...
Leaking faucet
Remove the handles. See if the chrome slip nuts holding the stems in are corroded. If they are, the cartridges may not be fully seated or the o -rings that seal around the cartridges may need to be replaced. If either of these is the case you can tell for sure by turning the stems to the on position with the handles removed and looking for water seeping around the cartridge. If none of the above is the cause then check to see if the aerator (screen on the spout) is loose or corroded sending a light spray back towards the faucet body that looks like a leak. If this is the case remove and clean the aerator, then reinstall it making sure not to cross thread it. If none of the above, replace the faucet. Be sure to call Delta first before replacing because they have a lifetime warranty and you just might get your faucet for free!
Leaking faucet
Secure your water
Determine the cause of the leak
Change the Seal on that side (Double Handle)
Change Cartridge on Single Handle
2answers
I have a serious kitchen sink leak from the cold water faucet. I've replaced all the parts that are replaceable: spring, washer, cartridge. It's a simple job and i am fairly sure that i did it...
If it's a Delta-type faucet, disassemble it and make sure that the little rubber "cup" seal is properly seated on the spring and in the seat. It's fairly easy to get one of them in slightly crooked, which will leak like the dickens. If it doesn't want to go into the channel properly, you can use a tiny dab of petroleum jelly (Vaseline) to lubricate it.
My Delta 2578-278 faucet is leaking, when it is completely shut off. What is part is most likely the problem ? Thanks Joe
Check outside water pressure to house. Should be 65 - 75 PSI. If good most likely the cartridge. Older faucet, do both sides to prevent future problems. Blade handles? Make sure you get Hot & Cold stems, they turn the opposite way with blade handles. Some cartridges are universal and can be adjusted to work either way. After removing the stem, check with a flashlight in the valve, delta has rubber seats and springs on many of their models. If so, replacement of the rubber seats may do the trick.
Many of these problems develop from poor maintenance on water heaters and high pressure. Water heaters, regulators, safety valves, supply lines, and emergency shut off valves at fixtures should be checked, cleaned and adjusted on an annual basis. Your local expert plumbing contractor should be able to assist you on that.
1helpful
I have a Delta Tub/Spout Pull Down Diverter that has a pretty persistent drip. The HOT and COLD handles are turned off and seem to be as tight as they can be. After doing some research online I believe...
If your Delta RP17453 Pull-Down Diverter Tub Spout stops dripping after 5 minutes, your ok. If it never stops dripping, you need to replace delta faucet cartridge(s) behind the handle(s). This is were the water turns on and off and stops the water flow to the tub spout.
Delta faucets are some of the easiest to repair, and parts are usually available at any hardware store or home center. If you have a two handle faucet, replace both delta seats and springs and stems. If you have a single handle Delta faucet, replace the entire cartridge.
Installed new delta leland 978 kitchen faucet. Water pressure from faucet is low. Cleaned screen and there was no change.Could there be a clog some where else in faucet system?
check the angle stop under sink as sometimes the washer gets lodged in the orifice to stop..make sure water is off to house before removing handle to stop...check the hose...then the stem and seat to faucet itself.
I put a new shower valve on a delta shower faucet with a handle for volume control and a handle for temp. control. When I turn the water supply on, the water runs continuously and I cannot shut it off no...
The first thing I would do is to start over Remove the cartridge and look behind it to make sure the Quad seal and seats and springs are all in place, It sounds like a least one of the seats fell out of their home. Also double check that the spring are in correctly with the tapered end pointing towards the cartridge. The link below may or may not be helpful.
http://www.deltafaucet.com/customersupport/documentation/1724-74.html?document=pd&documentIndex=0
2answers
I have a two-handle Delta faucet that drips.  With both handles turned completely to off, the faucet drips at a about 1 drip every 15 seconds
sounds like you need to replace the valve seats. if you shut the water off and remove the handles you will see the valves. you have to remove them and under that you should see these little black things. they come out but have springs under them so be careful. the black things are the valve seats. i would start by replacing them
1helpful
I have a Delta shower faucet model number 1324 and my shower head is leaking How do I get the faucet part apart I have a diagram, but actually looking at the insides it all looks like one piece I don't...
Hi Shannon:
The problem is most likely the seats and springs. You should purchase Delta Part # RP4993. I found some for mine at Lowe's for around $4.00. O-rings are available there too for about $2.00, and you probably should go ahead and replace them as well, especially if they feel dry and brittle.
You have to remove the handle, then unscrew the brass ring (or bonnet) with a pipe wrench, then just pull the cartridge straight out. Separate the lower cartridge from the upper by twisting a quarter turn to the left. Once separated, remove the black rubber seats and springs and install the new.
Top Delta Plumbing Experts
David Shaub
john h
Mike
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
