Zenith R56W36 56" Rear Projection Television Logo
Anonymous Posted on Sep 21, 2009
CRT Arch / Blue Tube, Now what do I do.
Zennith Rear Projection TV R56W36:
CRT Arch / Blue Tube, Now what do I do. Something simple or do I have to call the TV repair person
Anonymous
Level 3:
  • Master 647 Answers
  • Posted on Sep 21, 2009
Anonymous
Master
Level 3:
Answers
647
Questions
Helped
149842
Points
2098
Replace Blue Tube and re-align - Big job and expensive Tube cost min $300 + installation. You can see the tube arching internally?
Testimonial: "Thnk You , Had to buy all three tubes and have them alined or buy new tv "
2helpful
Hello I have several (7) blue lines in an arch pattern spanning across the entire screen. Mostly noticeable in dark to black scenes. Was wondering if anyone knows what causes this and if there is a way I...
The Blue CRT ( Picture Tube ) has a short. You may be able to do a temp fix by turning down the Blue CRT drive level ( Located behind the front speaker grille )untill the lines disappear. But its only a temp fix. The Blue CRT will most likely need replacement.
4helpful
2answers
Turns on for 30 sec then goes bright blue and goes back into standby. turn back on it does it agian
This is blue CRT problem in tv as it is rear projection tv that has three CRTs red-green-blue inside to project color picture on front screen.
Blue CRT (tube) will be replaced to fix the issue and it is job of Pro because lots of adjustments are required after replacement of tube.
Local tv repair shop will help you for that.
Thanks
1helpful
I have an RCA 52 inch rear projection tv. Model # HD52W59 The blue CRT is arching inside the tube and I get no picture on the TV at all. Is the blue CRT gone bad
Yes,the blue CRT is dead,arching indicate the high voltage not going through the CRT tube anymore.Try website like Tvrepairworld.com,check if u still can buy refurbish crt tubes.
2answers
Must have blown something...all of a sudden after 9 yrs of use...picture is distorted. seems to arch toward the middle and mostly red and blue. Can watch it but very very distorted. sup?
I had the same kind of problem with a projection tv I had it was as simple as removing the front panel to expose the lightbulbs where there are 6 screws two for each color one for focus and one for power if after adjusting theese and going into the setup and adjust the color calibration it still does not work you want to make sure the three light bulbs on the bottom are alll working as missing one light can cause tints and the distortion your talking about
Loud sound of air and screeching tv keeps powering down
Sounds like a CRT is arching internally. to confirm remove the covers to have a view of the picture tube necks- in adimly lit room you should see bue arching in one of the tubes. (there are three piture tube with glass necks)
Convergence problems.
Your convergence ICs are likely bad, not typically a CRT or tube going out. A repair shop will fix for $200-400 or if you are very skilled you could repair yourself.
Screen turns blue then shuts off.
I already replied but once again..
Symptom shows Blue CRT (picture tube) in your TV might defective and need to be replaced. Its high tech repair issue, so contact tv tech person if you don't have enough knowledge about tv repair.
Tv turns blue the shuts off.
symptom shows Blue CRT (picture tube) in your TV might defective and need to be replaced. Its high tech repair issue, so contact tv tech person if you don't have enough knowledge about tv repair.
I have no picture coming out of my blue picture tube
ok 2 things could be wroung one is u have a bad crt board one way to find out is swap the blue crt board with the red crt board and see if the blue comes up and now u have no red. now u can not swap it with green the green crt board is allways by it self noe if that does not work and u still have no blue it could be the picture tube or something from the video board that is blaking it out and without a scope u cannot trace it but if u are lucky it will be the crt board hope this helps u
2answers
Zenith rear projection tv 56"
You have a convergence problem. Go to the convergence menu or consult the owners manual on the convergence procedure and try to correct i if you can.. However if the red image is bowed and or not linear you will probably need to call a technician to repair your set. Most likely the red convergence output chip has failed. This is a common problem with all CRT ( picture tube) rear projectors. Good Luck. Happy Easter
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
