Washing Machines Logo
Question about Electrolux Washing Machines
Help. Washer door locked Electrolux EWF14922 9kg
I clicked accidentally on Delay cycle. That's when all this started. Err showed. Clicked StartPause. Chose 18min wash. All done, then locked. It's NOT the power point, or electricity. I've drained a little water from front drain bottom right but could not twist anti clockwise to remove fluff too tight. I've let it sit overnight off and unplugged. This morning can select other cycles but it won't start to wash at all.
2answers
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
2answers
Ewf1087 showing E62 and door locked
wait for 5-10 min. after turn off coz delay came from the pcb board,if not working anyway, i think the prob is in the door lock (defective)
2answers
Electrolux Eco Valve EWF1087 washing machine,will not programme?Won't accept Quick wash cycle, then stops halfway through
8 November, Today I picked this model off the footpath, yet to set it up I hope it works LeonZ -Reservoir, Vic.
2answers
My electrolux ewf 1030 get err 44 help me pls ?
E44 - It means "Door closure sensing circuit faulty".
Replace the circuit board and restart the diagnostic cycle to check further alarm condition.
When the washing programme is started by pressing the START/PAUSE button, the bi-metal PTC (contacts 3-5 on door interlock device, no.3 on electrical diagram) is powered by the triac (DOOR TY) on the PCB: after 2 - 4 seconds, this closes the switch (5-4) which powers the electrical components of the appliance (only if the door is closed). The door interlock prevents aperture of the door while the appliance is in operation.
Microprocessor recognize closure position by sensing circuit connected to J2-1 on electronic board.
At the end of the washing programme, the PCB disconnects the interlock from the power supply, but the door remains locked for 1 to 2 minutes (PTC cooling time).
electrolux-ewf-1030-get-qdylxco5jx0zjejqiwkxkzw5-1-0.jpg Dado
3helpful
A red padlock symbol is showing on the panel of my WCVH6800 front load washer. I can't change any of the wash settings. How do I fix this?
Here's what the Padlock represents:
Lock Function
You can lock the controls to prevent any selections from being made. Or you can lock the controls after you have started a cycle. children cannot accidentally start the washer by touching pads with this option selected.
To lock the washer, press and hold the DELAY START button for 3 seconds (on some models use SIGNAL button). To unlock the washer controls, press and hold the DELAY START button for 3 seconds. The control lock icon on the display will light up when it is on.
NOTE: The POWER button can still be used when the machine is locked.
3answers
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Electrolux EWX 14440 W Washer will not start
This sounds like what I am having. Machine tumbles but does not rinse. Some postings say this is the door lock problem. Google "Fridigdaire washer will not Spin" and page down to read solutions.
Electrolux dishwasher delays before starting
  1. To cancel the delay.press the delay pad again when the delay is counting down. The indicator light will go out and the cycle will start or resume immediately.
  2. To cancel the delay and the cycle, press Start/cancel once to drain and turn-off the dishwasher.
  3. Press Start/cancel twice to turn-off the dishwasher without draining.
I have a Splendide 2000 s vented washer and dryer. I started a load and there was water leaking all over my floor from the washer, so I immediately turned it off. Now I'm trying to get those clothes out...
Unplug it. Door latch has thermal delay. Unplug, let cool 3 minutes, open door.
After door is open, you can kill the delay: with door open remove rubber boot to access gap between door & drum, remove door catch from cabinet, glue, break or unwire delay parts & replace all. Do this with safety glasses, the spring holding rubber boot can be a bit jumpy.
Your leak I know nothing of.
6helpful
2answers
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
Top Electrolux Washing Machines Experts
David Shaub
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
