G975 Drying fan problem, water comes out of outlet after opening door. Peter
I have a Miele G 975 Plus. Whilst on the drying cycle the hot air outlet makes a gurgling sound because its full of water and when we open the door about 1/2 a cup of water pours out of the drying outlet, I have cleaned the drying fan and removed a lot of grime, I have removed the door skin and found the tube leading from the fan to a lower compartment was full of water too, I suspect the water shouldn't be in the tube and is not draining away. Any suggestions? Peter
If it like other Mieles, it has an element to heat water if required to reach cleaning temperature, but does not have a drying element. Even then, it should give off some heat in the drying cycle and be hot after finishing.
There could be water stuck inside the fan because the drain tube that runs into the combination dispenser is clogged. If this is the case the door would have to be removed in order to gain access the the hose. If you have a custom panel that will have to be removed first by opening the torx 20 screws on the upper right and left side (the screws only loosen they do not come out). After that panel has been removed you have three screws on the right and left of the door when its opened. Once these screws are removed the door panel will come off and you have access to the fan and tube. Remove the tube and clean it out; you could also stick a toothpick inside the opening of the fan where the tube connects and clean that out. If this does not help then the fan would have to be changed because a solenoid is sticking.
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
This
happens every year or two. Take off the outside front panel to access
the hose that runs from the bottom of the fan down to the dispenser, and
lets the water drain out through it to the interior. Clean out that
hose as well as you can. Replace. This is a stupid problem that Miele
should have a permanent fix for. Grrrr.
In fact I just did this with mine today. The hose cleans out quickly,
the problem is getting the front back on. 4 hands make it easier. It
slips on when you start close to vertical, then slip in in and down.
For putting the screws back in, you might have to use a micro
screwdriver to re-align the little clips on the door panel. (You will
see what I mean when you do it!)
This costs a service call ($100, give or take) to call for service. It
can be done at home with no added parts. I think it applies to all
Miele dishwashers, and I have now done it several times. As I said
before, this is a design fault and should not be necessary!
PS: I still have the puddle on the floor, so am trying again only 3 days later! But this has worked several times before.
Take the door fascia off, and you'll see a pipe from the steam outlet to the Soap Dispenser in the door.
Take that off, and flush out the small bit of food that is blocking the tube.
Put the cleared pipe back in situ.
Run machine, you should get steam, and no water.
When it blocks again, and you get the water again, repeat unblocking process etc...
The heater on this unit only comes on twice, once in the wash cycle, and again in the Sanitary rinse. During the drying cycle all that happens is a vent opens and a fan comes on. The fan removes the hot moist air from the unit and the dishes dry off. If your water is not hot enough, this is why your dishes are still wet. Rinse aid also helps to sheen off the excess water as well.
you need to remove the front of the door.there is a small pipe from the dryer fan to the top of the detergent dispenser. tis usualy gets blocked at the fan end. also the spout from the fan. this happens if you dont rinse loose food of the items you put in the dishwasher.
