Re: Panasonic RX ES29. How can I open a stuck tape deck...
Put a dinner knife in the gap and gently try to prize it open whilst pressing the button. If that doesn't work, you will need to open up the case and find what part is not working..
Hi i have penasonic vk90d after i service the unit . The unit is stuck on dvd but nothing works dvd tape fm aux nothing work the unit is stuck on dvd changer. Any body help me plz [email protected].
I think this should be a simple fix! The deck will have switches at the top of the cassette compartment. These detect the tape and also select it for type - metal or chrome etc. These switches have become bent or damaged or have dirt on them.
The very first mistake is to pry a door open. That damages them. You are never to do that. The correct way to get a tape out is to open the unit up and find out why the tape is stuck and then take action to release the door in the normal way- usually it is a loose belt or defective cam motor. As to the Pinch roller there are slide plates and even some pinch rollers had lubrication on them so that may have dried leaving you with a stuck part. The normal order of business is the find out what is stuck and then take action to clean and lubricate the mechanism to return to normal function. The problem with some Pinch Rollers is that there may be a particular spot it needs to be set at. This is true if it has a guide fitted to it. Then you will need either a jig or mirror tape to be able to set it correct again. I can not give any further advice without seeing the unit but this should get you started.
Your unit needs a little TLC. Let me address the likely problems/solutions:
1) Tape deck stuck - The most common problem here is that the belt has gotten slippery. This has prevented the mechanism from resetting to a known position and that is what prevents the door from opening. Hopefully when you pried it open, nothing bot broken.
2) Both tape drives run from the same motor and use different belts. The same applies to the second deck as the first. The belts are sliping and need to be replaced.
3) The CD lens is probably dirty and needs to be cleaned. The fact that the CD stops and an attempt is made to play it suggests that the optics are working enough to detect the disc. Clean the lens using a cotton swab and alcohol and that should resoplve the CD problem.
If you have not opened up these before, I would not suggest you start without someone around who has. There are 3 belts that need to be chagned for the cassette section to work. Plan on $15-$20 for the belts.
push the eject button at the same time get a nail file and insert it in the
tape slot
on the right hand side of the deck it may take three hands one to push eject one to push the eject mechanism
inside the radio behind the tape
and one to help remove the tape
if that doesnt work....dont try forcing anything as the stereo WILL break..... take the stereo out of the car, so it is not connected
to the electrics, then either, gently take it apart with a screwdriver
I would suspect the belts, look for any small motors and missing belts.
You may be able to manualy turn a wheel or gear till it ejects.
if your not comfortable doing this urself with the above said porcedures... its better to take it to the dealer...
regards
iversh
A very helpful rating is appreciated for answering Your Query
The problem here is that the unit is stuck in a partial position. The "reset" by unplugging and plugging back in usually causes the unit to reset to a known position. If there is no activity (no motor sound), it will need to be opened up and reset manually. If you hear the motor running for a short period, it is attempting to reset, but the belt is most likely worn or broken. These units are relatively simple, but a bit tricky to dis-assemble. This repair should not require anything other than a belt or 2. Figure on $3-$10 for parts plus the local labor rate for the repair.
there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
it happened to me also and that works perfectly
good luck
