Televison & Video Logo
Question about Toshiba Televison & Video
I have a cracked screen what parts do i need to replace it
Its a toshiba modle 50l1350u i beleave its led
Posted by Tadd wilks on
ADMIN Andrew
    Top Expert:
  • Toshiba Master
  • 57,455 Answers
  • Tadd wilks
    Tadd wilks Feb 21, 2022
    It fell and hit the corner of the tv stand ive searched all over and cant find a screen
Toshiba 50L1350U Tv no picture
mine had x6 swollen capisitors ,i replaced all 6..got off ebay,,and it works fine now,check them all first
Hi Mr Fixya, I have a Toshiba 50L1350U TV with a black screen. Yes I can see an image when I shine a flashlight on it, yes there is sound. What parts do you recommend?
Could be a bad power board or the LED's in the panel are bad...test the voltages on the power board that go to the lamps and see if its ok
I have a 50" Toshiba... Model # 50L1350u... I cut the TV on and the screen is black, when I shine a light on it I can see the picture..Can someone tell me the part I need
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board
1helpful
No back lights an black screen model 50l1350u
Getting horizontal lines on the bottom half of my toshiba 50inch led TV model#50L1350U, is there an easy way to fix this or I should I bring it in for repairs?
TOSHIBA 50L1350U LED TV WILL NOT TURN ON
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
