When you install Toast, one of the install questions is whether you
want Toast to recognize blank CD's or DVD's when they are inserted. If
this was set to yes, then I believe this could override the OS
acknowledgement and Toast will take over.
One way to check is to open up Disk Utility (Applications >
Utilities > Disk Utility) once you insert a blank disc, if you see
the blank disc, try using Disk Utility to mount it, than it will should
show on your desktop.
If you want the OS to mount the disc all the time, check your Toast settings.
Check both the preferences in Toast but also under System
Prefs-->CDs and DVDs...there is an option there to choose what the
computer should do when a blank DVD is inserted. Probably Toast set
that System Pref to "Open Toast" based on your install configuration.
The Finder Pref you refer to only determines if CDs and DVDs recognized
by the Finder show up on the Desktop. This is only a display
preference, not really a determination of whether the Finder is the
primary app that will recognize a blank disc. The CDs and DVDs panel in
the System Preferences is where you need to go.
if that doesnt solve ur issue... i wud recommend u to reset ur pram and smc.....
Resetting PRAM and NVRAM
- Shut down the computer.
- Locate the
following keys on the keyboard: Command, Option, P, and R. You will
need to hold these keys down simultaneously in step 4.
- Turn on the computer.
- Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
- Hold the keys down until the computer restarts and you hear the startup sound for the second time.
- Release the keys.
Your computer's PRAM and the NVRAM are reset to the default values.
The clock settings may be reset to a default date on some models.
Resetting PMU on PowerBook or iBook computers
In some troubleshooting situations, if resetting PRAM does not
resolve an issue, resetting the PMU may be the next appropriate step.
For information on when this is appropriate and for instructions on how
to reset the PMU in your PowerBook computer, see
Resetting PowerBook and iBook Power Management Unit (PMU).
Additional Information
Resetting NVRAM in Open Firmware
If your computer is Open Firmware-based (Power PC) and you are
unable to reset NVRAM as described above, you may alternatively reset
the NVRAM and Open Firmware settings using the steps in the Solution
section of
Message “To continue booting, type 'mac-boot' and press return”.
In some cases, an Open Firmware-based computer may not respond to
the keyboard commands noted above, and may not allow starting up into
Open Firmware by pressing and holding the Command, Option, O, and F
keys during startup. If you are unable to get to an Open Firmware
prompt (and your computer supports doing so), try powering on the
computer with the power button held down continuously—as if you were
doing a firmware update. This should force the computer into Open
Firmware, allowing the steps in the article noted above to be used.
Contents of PRAM
Some Macintosh computers may not have all the settings described below. For Mac OS X information, refer to
Mac OS X: What's Stored in PRAM?
- Status of AppleTalk
- Serial Port Configuration and Port definition
- Alarm clock setting
- Application font
- Serial printer location
- Autokey rate
- Autokey delay
- Speaker volume
- Attention (beep) sound
- Double-click time
- Caret blink time (insertion point rate)
- Mouse scaling (mouse speed)
- Startup disk
- Menu blink count
- Monitor depth
- 32-bit addressing
- Virtual memory
- RAM disk
- Disk cache
with respect to ur SMC...
The System Management Controller is an
integrated circuit (computer chip) that is on the logic board of the
computer. As the name implies, it is responsible for power management
of the computer. It controls backlighting, hard disk spin down, sleep
and wake, some charging aspects, trackpad control, and some
input/output as it relates to the computer sleeping.
Over time, the settings in the System Management Controller may
become unusable, which can result in operational anomalies with the
computer. Examples include not turning on, not waking from sleep, not
charging the battery, or not recognizing the AC Adapter, among others.
Resetting the SMC is not intended for resolution of a stall or
situation in which the computer is unresponsive. An SMC reset should
not be necessary except as a last resort in cases where a hardware
issue with the power management system is suspected. Performing an SMC
reset resets the hardware power management functions.
For most situations, a restart is sufficient. If the computer has
stopped responding, try each one of these steps, one by one. Test
between each step to see if it has worked. If one step works, don't
worry about the next one. You should only reset the SMC if you've
tried all of the steps listed here and the computer still isn't working.
- Force Quit (Option-Command-Escape)
- Restart (Control-Command-Power)
- Force Shut Down (press the power button for 10 seconds)
Only perform an SMC reset on the computer if
none of the
above steps resolved the situation. If this is the case, see below for
instructions on locating the reset button or key combination for your
model of computer. If your computer is earlier than the models listed
here, see "
Resetting PowerBook and iBook Power Management Unit (PMU)" or "
PowerBook: Resetting Power Management Unit (PMU)".
MacBook (13 inch, Late 2008), MacBook Pro (15-inch, Early 2008), and MacBook Pro (17-inch, Early 2008)
- If the computer is on, turn it off.
- Disconnect the AC adapter and remove the computer's battery.
- Press and hold the power button for 5 seconds and then release the button.
- Reconnect the battery and AC Adapter.
- Press the power button to restart the computer
Note: Starting with MacBook Pro (Late 2008) and
MacBook (Late 2008) models, you may instead use the reset method for
MacBook Air (below) to reset the SMC. All earlier models of MacBook
and MacBook Pro must use the method described above, which involves
removing the battery.
MacBook Air and MacBook Pro (Late 2008 and later)
- If the computer is on, turn it off by choosing Shutdown from the Apple () menu.
- Connect the power adapter to a working power source.
- On the built-in keyboard, press (left) Shift-Control-Option along with the power button once.
- Wait 5 seconds and press the power button to start the computer.
Note: You must use the keys on the left side of the built-in keyboard.
You should only perform an SMC reset when the MacBook Air or MacBook
Pro (17-inch, Early 2009) has been properly shutdown. This prevents
issues from occurring to the file system.
While the power adapter does not need to be connected to reset the
SMC, it may be necessary in situations where the battery needs charging
or if the computer has been without power for an extended period of
time. You can also visually check the SMC reset by observing the LED on
the adapter. It will momentarily turn off as the SMC resets.
Hi andres hermoso, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
