I have an AEG B5741-4-m Cooker. It turns on to standby but when I turn the oven on and go to set a temp it trips the fuse in the consumer unit. Would this be caused by a faulty heating element?
thank you
Please add a comment with the model number for direction specific to your oven. I will attempt to determine if there is a different combination to enable or disable the child lock feature. Note: at least one AEG microwave/grill uses Press "Micro+Grill" once. Then press "Clear/Stop" 5 times to toggle the child lock on and off.
In a simple oven, this could be be due to a heavy current due to a fault (check with resistance meter) or if the resistance is OK the tripping could be cased by an 'earth leakage' which typically presents when an appliance is damp or a heating element has not been used for a while...
I'm afraid you have a bad board. I had a neighbor with the same problem and he had to replace just the stove top part. Hopefully, yours is just the temp setting part, but it may not be that if you can control the oven setting.
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
