How do I play a ntsc disk on a toshiba D-VR610KU model
My Toshiba D-VR610KU model IS old, but when I looked up this problem on Google several websites said that this Toshiba model WAS made to play ntsc disks. If that is true, how do I get it to work ? Thanx
Top Expert:
Toshiba Master
Re:
It may well play NTSC disks but it won't convert the standard to PAL or whatever your system is. Check your TV will display NTSC 525line pictures with 30HZ frame rate.
Testimonial: "Thank you for your answer but unfortunately I don't know what PAL is or how to determine 525line pix w. 30HZ frame. This disk will not load to begin with. It gets almost to the end loading & then it stops."
It is not compatible with your player then, if other disks with the correct region code work.It is not compatible with your player then, if other disks with the correct region code work.
You can't post conmments that contain an email address.
Go into system , then disk settings , you should have a option to play NTSC on PAL select this and your region 1 discs should play with no problems. NTSC is region 1 format
DVD player region-free codes.The DVD player can play both NTSC,and PAL.Play all NTSC DVD this format is in US,Canada,Mexico.PAL DVD format is in Europes,Asia,and Middle East.
ACCORDING TO THE TECH AT TOSHIBA: THE UNIT MUST BE CONNECTED TO THE TV BY AN HDMI CABLE FOR THE DVD PART & (ON THE BACK-RIGHT HAND SIDE OF THE COMBO) YOU NEED TO CONNECT A SET OF THE RED/WHITE/YELLOW CABLES FROM (VIDEO) "OUT" OF THE COMBO & "IN" TO THE RED/WHITE/YELLOW TV(AV-1) PORTS FOR THE VCR PART TO WORK.
All coaxial inputs or outputs on any unit is the screw-post type. The female part is a standard coaxial cable that slips onto the posts on the unit. Are you trying to convert Coaxial to RCA?
What are the compatible types of DVD's that the Daewoo DVD5800 player is supposed to play? Is DVD-R among the compatible types? Try playing the new recordings on a computer that has a DVD drive, or a friend's computer.
Based on information provided by the manufacturer, this specific model (Toshiba D-VR610) was built to meet NTSC standards. Due to the similarities between the NTSC and PAL-M formats, this model should be able to support both types of video tapes, but remember that you will most likely need to use a TV that shares the same format as the tape being played to avoid a "washed out" or monochrome image.
Additionally please keep in mind that because this player supports the NTSC format, it was most likely built for use with Region 1 (U.S. and Canada) DVD's only. While some manufacturers do provide region-free support in their players, you would need to speak with Toshiba directly for more information regarding the availability of this feature.
