Washing machine over revs and trips breaker during spin cycle. UK
During the spin cycle, the machine will sound like it's spinning up even faster, followed shortly by the breaker tripping everything in the house. The lights, the sockets, everything.
After tripping there's a pungent electrical burning smell like Ozone.
We've had a tech around to check it, but they said they can't find anything wrong.
Model: Hotpoint WMFG 651 Futura
Re: Washing machine over revs and trips breaker during...
There must be something wrong with the computer board, I would try getting some one else to have a look at it,if its triping the braker on the fuse board it must be the washing machine
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
This tells me that you do not have an overload situation. There is a short, and/or one or more faulty breakers possibly including the main breaker.
Even an experienced DIY'er with electrical knowledge would probably contact an electrician at this point. If there is a potential problem with the main breaker then it is best to get professional help.
Sounds like corrosion in the motherboard . Get an electronics serviceman to take a look, could just need soldering point to point connection. Hope this helps.
try unplugging the motor then put onto spin it will pump out ok and run othewise spin if all else is fine ,next reconnect the motor if it trips again then motor ' fault; repair /replace.
If this sound starts slow and gets faster till its helicopter sounding you probly have a verry worn spot on the drive belt when that spot goes around the pully it will thump the faster ti spins the more frequent the sound If you tilt the washer back you should be able to see the belt to examine it if this the problem
replace the belt
Hope this helps
please leave feedback
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
