I have a problem with my dp29f, after I push the stop button, the arm returns to the 0 position, only every time I have to manually push the black plastic part the one that raises the arm otherwise it won't turn off. I tried a screwdriver, but the screw is only for adjusting the height of the arm. I just don't know what to do! Thanks! Giorgio
The deck requires servicing by a Denon Service Tech.
Testimonial: "I thought it was possible to disassemble the arm part to reset the gears."
Upon disassemby, you may find damaged gears or teeth and new plastic parts will be required in that case.
do you have a detailed parts manual? I can only find the user manual.
Page 10, item 154 will be your problem. It needs to be cleand and don't use any oil on it! https://manualsbrain.com/en/manuals/1810...
