Question about Samson Audio C01upak C01u Microphone and Podcast Pack
Only a dynamic mic works on my lap top not condenser mic
I useed the dynamic mic on lap top for recording vocals n didnt like the sound so got a amp-87s condenser mic and tube ultragain mic 200 it works on my mates lap top but not mine.
Posted by scarface360 on
  • Anonymous Mar 12, 2014
    how to change tubes in an ultragain pro mic 2200
Fred Yearian
  • Samson Master
  • 5,603 Answers
Make sure the 48 volt phantom power is on.
Remember this preamp has TRS BALANCED output. If you run this with a stereo adapter into your laptop, the signal and the inverse will be sent into the L and R channels of your laptop and they will CANCEL!
You need to use a special cable that takes say just the tip of the cable from the ultragain connecting to BOTH the left and right inputs of your laptop.
Posted on Sep 22, 2009
How can I reduce white noise / hissing I'm getting over the mic on a Behringer Xenyx 1204 USB setup?
Hi, you didn't say if the mic actually passes sound? The C-1 is a condenser Mic & needs phantom power - switch on the rear of your mixer. If that's no help, what happens if you disconnect the mic, then turn the levels back up? Still hissing or gone? If it's gone then it's the Mic - must use a 3 wire cable, preferably XLR so it gets the phantom power. If the hiss is still there without the Mic then sounds like the mixer is faulty - try some of the other channels..... How loau is the hiss - just in the background or as load as a vocal "one, two" test? A few things to check anyway...... Good Luck!
Dec 01, 2016 | Behringer Music
Tip
Home Studio Recording: Part 3
Once again, we dive into the subject of recording your band's (or your solo) album. So far, we've covered the basics, and how to record drums. Today, we talk about the all-important Bass Guitar.
There are a few different ways that you can do this, one being the industry studio standard of using a Direct In box, or DI. How this works is you run through this box, which then has two cables. One to the mixer, and one to your amp. You then mic the amp (see below for mic placement), and get both the clean and amped signals together on the track, giving you a fuller sound.
Method number 2 - Amp your bass, and add the effects there at the amp. Compression, chorus, and distortion are some popular ones with the bass guitar these days, even in country music. Light overdrive gives a bass more high end sparkle, making it easier to hear it at the lower volumes.
Method number 3, and suggested if you don't have a DI box as well as if you don't want to anger your neighbors, who bang on the ceiling with a broom (just joking on that. Still, don't tick them off!) - Plug your bass straight into the computer, and record two tracks simultaneously. On one of the tracks, apply an amp simulator with the desired effects. On the other, apply ONLY an equalizer and compressor, in that order. What this does is gives you the amp tone, as well as accentuates the lower frequencies of the bass guitar. It's the shortcut that actually produces great results.
For mic placement on your amp, you can use either a condenser mic (which requires a preamp, or a mixer with phantom power), or a dynamic mic. Both will give you a great sound, but it's up to you to find what fits your sound, and your budget.
Placing the mic. - Pick your best sounding speaker. To do this, turn your amp down, and play a note. Go to it, and listen to each speaker by placing your ear directly in front of it (this is why we said turn it down). If your best one is close to the floor, rotate the cab so that it's one of the top speakers. Using a standard mic stand, place the mic so that it's pointed directly at the speaker, but it's about 2 inches in front of the cone, and 2 inches to the side. You can experiment with different placements, such as directly in front, or to the side and pointed across the speaker, but this is usually the best sound you'll get.
That's all for this segment of Home Studio Recording. Join us later for part 4.
on Mar 27, 2011 | Music
I have a lexicon alpha, samsung CO1 condenser mic and a samsung phantom power box, i have all the correct wires but i dont think i am connecting the correctly, HELP ME ! lol
Sorry, but the Alpha does NOT have Phantom power which IS required for a condenser mic.
You will either have to get a mic preamp that supplies phantom power or go to a dynamic type mic if you stay with the Lexicon Alppha.
Jan 17, 2011 | Lexicon Alpha Personal Recording Studio
Im having a problem with hearing my b-1 studio condenser mic on the lexicon alpha progam?
Sorry but... Very simply, you CANNOT use a condenser mic with the Alpha since it does not supply the required Phantom power for the mic. You must step up to another interface to use condenser mics. You can use dynamic mics with the Alpha or other audio sources. I use a Roland/Cakewalk UA25E interface with condenser mics and also the Lexicon Omega which does have Phantom power for the mics..
Nov 03, 2010 | Lexicon Alpha Personal Recording Studio
Have just purchased lexicon alpha to use on a Mac. Having trouble just getting started. Have hooked up a nice condenser mic into the alpha through the mic input on the rear and cannot get anything on the...
Make sure you have Phantom power turned on on the Lexicon... Oh,oh... it appears that the Alphs may NOT have phantom power which IS a REQUIREMENT for most condenser mics...
The Lexicon Omega does have this but apparently the Aplpha doesn't have it.
That leaves you with the choice of either getting a dynamic mic that doesn't need Phantom, or replacing the Alpha, OR using a preamp ahead of the mic before the Alpha...
Sorry, but those are the only solutions I see for you.
REMEMBER that condenser mics pick up everything and you cannot run them into a PA or they will feedback.
Oct 08, 2010 | Lexicon Alpha Personal Recording Studio
I want to record vocal voice trhought mic on psr 9000
You could record short "samples" to be used in building new voices, however, it does NOT appear that you can record a vocal song with the PSR9000. The Tyros II and III have the capability to record vocals but the PSR9000 and Tyros I do not..
When playing back an arrangement, you can re-sing the song and have the vocal harmonizer track the arrangement.
Jul 29, 2010 | Yamaha Music
I have a behringer xynyx 1204,and a protools personal studio,with mbox2 mini,and im just wondering if its possible to plug the mic into the mixer,instead of the mbox,and still be able to record vocals into...
It is possible, you can simply put a Y-cable for Mic or a splitter for the mbox and the Mic. You can plug the mic directly to the mixer then the other jack on the splitter connected to the mbox.
Jul 25, 2009 | Behringer Music
Samson C01U USB mic not working on my PC.
try this;
1.using different usb inputs on your pc desk top
2.update drivers on both your desk top and laptop
3.using a different usb cable
if it works fine on your friends computer most likely its not the mic
Feb 25, 2009 | Samson Audio C01upak C01u Microphone and...
Samson Audio C01upak C01u Microphone and Podcast Pack Logo
174 people viewed this question
Top Samson Music Experts
Lawrence Oravetz
Vernon Taylor
rhodesworks
Are you a Samson Music Expert? Answer questions, earn points and help others
