Computers & Internet Logo
K
Kristi Williams Posted on Jan 31, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my lasko 5842 model keep kicking off and I keep the filter clean
I've tried to reset it numerous times
Steve Pack
Level 3:
  • The Master 7,121 Answers
  • Posted on Jan 31, 2022
Steve Pack
The Master
Level 3:
Answers
7121
Questions
Helped
2271002
Points
27862
Answer is in instructions
Save-Smart®
Press () to activate the Save-Smart®Function.
1.Set the thermostat to desired temperature using the +/-
buttons (Note: The default Save-Smart®temperature is 72 ? F)
2.When you reach the temperature at which you want to
set the unit, the set temperature will flash several times
and then the display will return to indicate the current
room temperature and will gradually change as the
room temperature changes.
3.When the air temperature is less than the set temperature,
the heater will run in HIGH heat.
4.Once the thermostat reaches the set temperature the heater
will automatically switch to LOW heat to save energy.
5.When the air temperature reaches 4? above the set temperature,
the heater will turn off. The Heater will cycle off and on in the LOW
mode to maintain the set temperature.
All this happens automatically with Lasko Save-Smart®Technology.
To deactivate the Save-Smart®function, press Save-Smart®
again or (hi/lo) for continuous high/low heat.
AUTOMATIC TEMPERATURE CONTROL(Figure 3)
The automatic temperature function will only operate on "High" heat.
You cannot set the temperature automatically when the unit is in the low heat mode.
1.To set the room at a specific temperature press the () or()buttons
to the desired temperature. The display will now reflect the () and the temperature will be flashing. The Heater is now in Auto Temperature Mode.
2.When you reach the temperature at which you want to set the unit, the set temperature will flash several times and then the display will return to indicate the current room temperature and will gradually change as the room temperature changes. NOTE: the temperature display does not indicate the temperature of the heated air being emitted by the heater.
3.Once the room temperature reaches 2 degrees above the set temperature, the Heater will shut off. Once the room temperature reaches 1 degree below the set temperature, the Heater will turn back on and continue to cycle off and on to maintain the set temperature.
4.This function will cancel if the ()button is pressed. The Heater will now be in High heat and run continuously.
NOTE:It is normal for the Heater "fan" to run for approximately 15 seconds when the Heater shuts off after reaching the set temperature.Press the () and() buttons at the same time to change the display to ° Celsius. Press the same two buttons together again to change the display
back to ° Fahrenheit.
How to change filter on my Lasko model 5560 Tower Fan Heater?
Question edited for clarity.
They show your model, and if it has a filter (not mentioned in specs), My guess is the you lift up the black piece at the rear.
https://lasko.com/collections/lasko-heaters/products/lasko-5560-digital-tower-heater-with-remote
The manuals are very basic and your model isn't listed. Model 5309 below.
http://images.salsify.com/image/upload/s--U1j83tBG--/fsxod4mxrt0iju3nfsdv.pdf
There is a contact link if you click Support on the upper bar.
https://lasko.com/pages/product-instruction-manuals
.. Videos that MAY help?
The water-in-fuel warning light keeps coming on..have changed the filter and drained numerous times have put diesel power liguid in the fuel as well but still keeps coming on..?
You didn't tell us what this is, car truck generator etc, make model serial. Generally if you have done what you said, you need to find that sensor. Usually part of the filter assembly. Try cleaning it well. You may have to replace it. Search for [make][model][year]WIF sensor.
I have a singer confidence 7469 quilter, the upper thread keeps bunching up in the bobbin case. I've tried re threading numerous times with no luck.
try changing the needle
make sure the bobbin is turned the correct way in the bobbin case
make sure the thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
3helpful
How do you clean the ionizer in a lasko wind curve
You have to take the fan apart. They didn't design it with the convenience of the customer who likes to keep things clean in mind, so you have to get out a bunch of screwdrivers and stuff and roll around on the ground and fight with it until you get it apart. I posted a lengthy post on how to get this model apart, as I just did mine yesterday. Just look for my name on the Lasko models like this one. But be careful and don't try it if you don't think you can pull it off without getting hurt.
5helpful
Won't turn on. It gave me a beep when I plugged
Have you cleaned the filter that's on the back? This has happened to me, and I just took the filter out and cleaned it, and it worked fine after.
2answers
Clean the filter : Lasko Model #5812
First make sure heater is unplugged. Next, on the side of the heater locate two holes (see image) these are what's keeping everything in front together. unscrewing these and genty pulling sides out lwill release the top filter and front where control knob is and bottom filter where the heated air comes out. Clean filter & re assemble.
3helpful
I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
9helpful
How to clean filter on Lasko tower ceramic heater
Thanks for the response = I blew the filter clean with a forced air canister.
Top The Computers & Internet Experts
Alexander
vince
Steve Sweetleaf
Steve Sweetleaf
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
