Hello, I have a Frigidaire Gallery Microwave from 2013 # FGMV-174KFB, and need to replace the INTERNAL light bulb, but I do not see anywhere where I can find screws or any cover that can come off. This unit is the above range/stove kind and has stainless steel trim all around it, which can't be popped off or anything. There is simply nothing I can pop off or unscrew at this point. How do I get into the unit and change the bulb? Is the only way to pull it completely out of the cabinetry? I hope not. PLEASE HELP.
You are lucky!
MICROWAVE OVEN LIGHT Remove the louver per instructions 1-3 above and charcoal filter, if used.
1. To replace light bulb, first disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
2. Open light cover located behind filter mounting by carefully pulling up on the front edge.
3. Remove old light bulb and replace only with equivalent watt bulb available from parts distributor. Bulbs are also available at most hardware stores or lighting centers. DO NOT USE BULB LARGER THAN 20 WATTS.
4. Replace the microwave oven light cover by carefully pushing into place. Replace the charcoal filter, if used. Push the louver back into place (engaging both the bottom and top tabs) and replace the louver mounting screw.
When in doubt, refer to the manual :>D
https://d1vofmza27mmhi.cloudfront.net/product-pdf/frigidaire-fgmv174kf-use-and-care-manual.pdf
Thanks for the info, but I need more specifics. I don't know how to get to the inside of the microwave because it is in our cabinetry. Please help!
You get to it from behind the top front panel. Did you look at the link and go to Page 24? It is behind the charcoal filter. I don't know how I can make it more 'specific'.
Hello - This may or may not be specifically for your model, however these are generics instructions that I found.
To replace the light bulb to the over the range microwave you will need to follow the steps below:
2. Remove the vent grill mounting screws.
3. Pull the vent grill away from the unit.
4. Remove the charcoal filter by pushing it inwards, then turn and pull it away from the unit.
5. Open light cover located behind filter mounting by carefully pulling up on the front edge.
6. Remove old light bulb and replace only with equivalent 30 watt bulb available from part distributor. Bulbs are also available at most hardware stores or lighting centers.
7. Replacing the microwave oven light cover by carefully pushing into place. Replace the charcoal filter. Push the vent grill back into place (engaging both the bottom and top tabs) and replace the vent grill mounting screws.
Note: DO NOT USE BULB LARGER THAN 30 WATTS.
