Question about Electrolux Washing Machines
Not rinsing/draining completely; cleaned out drain hoses, but still soapy items even after several cycles to get rinsed. With replacement pump installed, albeit not orig part# match, now water is not filling tub. I don't believe the new malfunction w/ water not filling is fr valves or selenioid, but am more inclined to think drain pump not being precise is causing it. Just trying to avoid hassle of return & new purchase w/ more $, winter ice injury,& my disability playing into my difficultly presently. Thx!!
I would say you need the right part. Although they might look the same, the wiring to the pins might be different. Here is the part
Fits your EIFLW55HIW0 Washer!
Part Select Number PS2342436
Manufacturer Part Number 137038700
Manufactured by Frigidaire
https://www.partselect.ca/PS2342436-Frigidaire-137038700-Drain-Pump-120V-60Hz.htm?SourceCode=20&SearchTerm=EIFLW55HIW0&ModelNum=EIFLW55HIW0&ModelID=1522373
I can't find the one they gave you.
https://www.google.com/search?q=washing+machine+pump+%23137408
Posted on Jan 26, 2022
Hello friend, thank you very much for your inquiry!
After reviewing the information you have provided regarding your Electrolux front load washer EIFLW55HIW0 having an E35 error code, I have found E35 is an indication of a water over fill problem. If the water fills above 4.5 inches please follow the below trouble shooting steps I have provided for you. If the water is not above 4.5 inches you may need to change the pressure sensor switch.
If the water enters continuously please unplug the washer to see if the water stops. If the water does not stop your issue may be the water valve assembly. If the water does stop the wiring to the water valve assembly needs to be checked. If the wiring is good the control board may need to be replaced.
I do suggest you seek a professional technician to look into this issue further to avoid any unnecessary part purchases. - T
